K19
posted on 13/6/17 at 12:43 PM |
Floor Mounted Pedal Box Bolts
My build has a floor mounted pedal box, and this means there are bolts through the floor and show on the underside of the car.
Will these need covers/anything else, or does it fall within the exempt area and doesn't matter?
I have no idea what I'm doing.
adithorp
posted on 13/6/17 at 01:59 PM |
The underside is exempt from the edge radius rules.
http://jpsc.org.uk/forum/
mcramsay
posted on 13/6/17 at 04:31 PM |
I put nut caps over all exposed nuts and bolt heads externally visible on the car, not needed but it pleased the IVA man as it looked like I had put
some thought into it!
scudderfish
posted on 13/6/17 at 05:20 PM |
If you're likely to injure someone with the radius on the nuts/bolts, then those nuts/bolts are probably the least of their worries.
