birdii
posted on 12/12/17 at 10:16 PM |
IVA Pass Today!
IVA passed today, first time. Feeling pleased with myself tonight!
My test was at Nottingham with Andy and I think he was very reasonable with his approach and advice.
There were a few problems along the way:
Radius on the headlights - the screw that holds the lens on. A nut cover fixed this.
Alternator cable needed a tie wrap.
Rear number plate didn't have 45degree angle of visibility - this one came as a surprise, I had put the number plate between the fog and reverse
lights but as they are 60mm deep it obscured the plate. The plate light was flipped and problem sorted.
Emissions were out, easily fixed with a fuel adjustment as I had my laptop and it was the non cat test so not difficult to achieve 3%co.
The brakes surprised me, I expected to struggle on the rear brake effort but it was fine and the fronts locked first no problem.
Andy didn't like the lock wire the bias bar and asked me to add a lock nut which I had no problem with. One rear brake was lazy on the handbrake
but just passed.
Headlight aim was good too which was another surprise as I had only set using some lines on a piece of card in the garage.
And lastly the noise test, it was tested at 5500 which was higher than I expected (max power 6400rpm) but just passed at 98db. I had measure 96 at
4800 using a good noise meter so I didn't really expect a problem.
After all the long days, late nights, early starts and stressing I'm now feeling a bit tired.
Brilliant day though and one that I will long remember! hard to believe I started this in 2005 and planned to be finished in 2 years, misjudged that
slightly. Unfortunately I will be revisiting the test centre in the near future as I left my build folder behind - must have been too excited!
Would love to upload a few photos but I cant get the archive to accept them so will try again tomorrow.
Dan
HowardB
posted on 12/12/17 at 10:23 PM |
Congratulations
best keep off the roads for a bit though - salt and ice - never a good combination
Howard
birdii
posted on 12/12/17 at 10:27 PM |
I think the dvla will keep me off the road, 6 weeks and still no v55/5!
Does that online form order system ever work? I’ve tried several times over the past few weeks but nothing has come.
Daf
posted on 12/12/17 at 10:44 PM |
Pictures pictures pictures!
pekwah1
posted on 12/12/17 at 11:24 PM |
Good work!
For reference, my v55 came through in about a week.
I also got one sent to a friend at his address as backup....
bonzoronnie
posted on 13/12/17 at 08:14 AM |
Huge congratulations.
I can well imagine how pleased you are, well done.
posted on 13/12/17 at 09:20 AM |
Congratulations
When my MK Indy passed it's SVA some years ago I remember a rather large dose of good feelings!
posted on 13/12/17 at 11:31 AM |
I look out my work window (Basingstoke, Hampshire) and it's pi55ing it down. Don't let that put you off though - I drove my car over a
couple of winters. Wrapped up warm and taking care it's good - the roads are quieter and the thrill of driving a car you've built really
is worth it!
adithorp
posted on 13/12/17 at 11:37 AM |
Nice one!
Must feel good after all the stress about the weather.
Registration form delivery from the on-line order is usually quite quick. I'd order another one and see what happens.
http://jpsc.org.uk/forum/
birdii
posted on 13/12/17 at 12:51 PM |
I feel very relieved to get that hurdle out of the way!
Ive asked a couple of friends to order the form too but nothing has arrived yet. Hopefully i will get it soon.
Will try again to upload a few photos tonight.
Dan
birdii
posted on 13/12/17 at 12:54 PM |
Same message on the photo uploads, unnsuported file type. Never had that message before using this camera.
Slater
posted on 13/12/17 at 03:40 PM |
Well done on the pass!!! Bet you can't wait to drive it. As others have said, be careful, even if the road is just a little damp you can easily
spin off with just a small touch on the throttle.
by the way......all the best folk pass 1st time
tims31
posted on 13/12/17 at 06:21 PM |
Congratulations, well done for a first time pass.
I'll be on the look out for you when the good weather comes. Maybe see if there are a few others around the Lincoln area who want to meet up in
the spring
Build: http://www.martinsfurybuild.co.uk/
robinsoncrusoe55
posted on 13/12/17 at 08:18 PM |
Well done !!!
Big pat on the back for you .... great to hear !
birdii
posted on 13/12/17 at 10:00 PM |
Managed to get a few photos uploaded, taken a couple of days before final IVA prep:
[img]
[/img]
[img]
[/img]
[img]
[/img]
[img]
[/img]
[img]
[/img]
[img]
[/img]
[img]
[/img]
[img]
[/img]
ttalps2000
posted on 14/12/17 at 09:07 AM |
Why did they test the RPM at a much higher level?
Chris_Xtreme
posted on 14/12/17 at 10:03 PM |
well done mate, great feeling.. I never took my cars off the road over winter. a couple of us used to go out rain , snow or shine of a Sunday
morning -- before the kids came a long and I let the car go.... make the most of it and take it easy.
jps
posted on 15/12/17 at 11:40 AM |
Looks great - what thickness alu did you use for your dash? I want to make one very similar but not sure how thick it needs to be...?
birdii
posted on 17/12/17 at 08:27 AM |
Documents all sent off to the DVLA now, after waiting weeks I got three V55/5 forms arrive in 2 days! I've also had the VIN letter arrive again
so presumably my dealer stamped reply never landed on the correct desk, I sent it recorded delivery so I know it arrived somewhere!
My exhaust is the old Robin Hood silencer which you would expect to fail on noise, if I was the tester I would want to check that whatever bodge was
reducing the noise was permanent enough, he was probably expecting a bunch of wire wool to fly out!
I think it was 1.2mm left over from the body sides, bottom edge rolled around a scaffolding pole. I'm hoping to change it to a GRP dash at some
point as I don't like the straight bottom edge.
Dan
ttalps2000
posted on 18/12/17 at 09:25 AM |
Good old IVA and make the rules up as you go along!! Well done on the pass though!
Mr Whippy
posted on 18/12/17 at 12:30 PM |
worth phoning just to check there's no issues. Their normally quite friendly and I just say I'm checking to see nothing was lost in the
post... their systems are quite good for giving progress updates
