Author: Subject: Reverse switch /button
dunk3
posted on 30/5/18 at 04:22 PM Reply With Quote
Hi all , what have you all used to switch your electric reverse gear on, I. E switch or button and does it have to be heavy duty. Any links to the switches or buttons would be helpful.
CosKev3
posted on 30/5/18 at 05:29 PM Reply With Quote
If you want to have the switch wired direct to the reverse you will need the likes of a starter or horn button,heavy duty.
If you want to wire in a relay that the switch activates you can use whatever switch you fancy then.
I've used a starter button with a rubber cover on it
CosKev3
posted on 30/5/18 at 05:35 PM Reply With Quote
http://www.halfords.com/workshop-tools/garage-equipment/fuses-electricals-fixings/halfords-heavy-duty-push-switch-hef358
I've used one of those
Hopley89
posted on 30/5/18 at 08:30 PM Reply With Quote
I wired mine from the Neutral Light to a switch on dash (with small red led under the switch) to a push button
under the hand break leaver
The small led is so i know it’s activated on dash when in neutral as i don’t want to keep the reverse light on if sat at Traffic light in neutral!!
ReMan
posted on 30/5/18 at 09:13 PM Reply With Quote
Well if its working thats great, but I think a starter , even a small bike one will take a lot more than 16 amps?
Though possibly less in this application that spinning an engine?
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
CosKev3
posted on 31/5/18 at 03:45 AM Reply With Quote
It's only firing the solenoid though,the main power is on the wire direct from the battery.
Makes no difference if it's spinning over a 1ltr bike engine or trying to reverse a 600kg car the solenoid won't draw any more current whatever
[Edited on 31/5/18 by CosKev3]
JekRankin
posted on 31/5/18 at 09:10 AM Reply With Quote
Wired mine through a toggle switch with an inline 10A fuse. No problems so far. The switch is an Apem 600 series and is rated at 15A if I remember correctly.
dunk3
posted on 31/5/18 at 03:54 PM Reply With Quote
Thanks for the replys guy's, think I will go toggle switch with led light to tell me it's on and 20amp push button to engage reverse . Cheers
ReMan
posted on 31/5/18 at 08:58 PM Reply With Quote
HA HA
What a t1t, it was early and I'd forgot all about that most modern CAR starters have integral solenoid,
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
