Slimy38
| posted on 8/12/25 at 11:23 AM |
Distance driven for an IVA test
I'm getting my IVA booked in, and calling them for Kidderminster, Derby and Nottingham reveals that the first two are booked up for January and
February, and Nottingham is closed. I'm waiting for a call back from a private facility in Castle Donington, but if that has no availability
I'm going to have to go further afield.
The next ones are 80-100 miles away. Is this a pretty standard thing, has anyone else had to travel 2-3 times as far as expected in order to get an
appointment? I suspect a 2 hour drive followed by a 4 hour test then another 2 hours drive will make for a very tiring day, especially if the
appointment is first thing.
Sanzomat
| posted on 8/12/25 at 11:53 AM |
If you do end up travelling that kind of distance it might be worth considering Avonmouth (about 90 miles from Wolverhampton). Everyone I know who has
been tested there is very complementary about how friendly and helpful the staff there are. No idea how busy they are though.
| posted on 8/12/25 at 12:00 PM |
Winchester to Southampton for my SVA test - 18 miles (with a support car following).
JAG
| posted on 8/12/25 at 02:39 PM |
I did my SVA (back in 2005) at Nottingham and drove from Studley in Warwickshire.
It's roughly 65 miles and took nearly two hours, I had a friend follow me there and back.
It was fun to actually drive the car - although it started snowing while I was on the M1
Justin
gremlin1234
| posted on 8/12/25 at 02:49 PM |
something in my memory says the private test sites don't do kit cars. but this may have changed.
Slimy38
| posted on 8/12/25 at 03:55 PM |
Yeah I contacted them this morning and it's been unusually quiet...
Slimy38
| posted on 8/12/25 at 03:57 PM |
Yeah that's the Bristol site isn't it? I've got Bristol, Chadderton and Leighton Buzzard as the next 'tier' of test stations,
all around 100 miles away from me. I'll give them a call tomorrow and see if there's any available, thanks for the recommendation.
Slimy38
| posted on 8/12/25 at 03:59 PM |
You're both braver than I am, I'll be hiring a trailer for my test! Hopefully once the car is registered I'll build up the confidence
to drive longer distances but for my first drive I'm not brave enough to go that far.
Slimy38
| posted on 8/12/25 at 04:13 PM |
OK, booked in at Bristol in February...
gremlin1234
| posted on 8/12/25 at 07:53 PM |
excellent, good luck,
I still suggest posting some pics so the experts here may give their insightful knowledge
ps someone here had a problem taking their car on a trailer to Leighton Buzzard, as there was a width restriction about half a mile from the test
centre.
| posted on 9/12/25 at 08:58 AM |
The Southampton test site is very close to Southampton docks. It had a constant stream of Japanese import cars rolling through being inspected and
given the ALL CLEAR to drive in the UK. The drivers bringing these cars through were on first name terms with the testers and it was a slick
operation. Most of the cars were 3-4 years old and looked almost new.
Sanzomat
| posted on 9/12/25 at 09:04 AM |
"had a fantastic day at the test center even thought it failed , but only on 7 items
1 brake low pressure to the rear brakes ,I think it may be still air in the system as i have been having a torrid time bleeding the system
:emoji_rage:
2 The pivot pins to the bonnet i had forgot to fit R clips:emoji_flushed:
3 I had wired the fog lights to the side lights and not dipped beam :emoji_upside_down:
4 The fuel filler cap wasn't tethered to the fuel tank :emoji_upside_down:
5 speedometer was out of calibration
6 I had a brake flued label but it wasn't marked up with the appropriate .4 fluid :emoji_upside_down:
7 I had the wrong weights on the vin plate they should have been Gross weight not curb weight :emoji_rage:
The guys at Avonmouth are fantastic they are very helpful
Now to get all the fixes done and get it booked back in for a retest ASAP
All in all a very positive day and im the little bit closer to being able to get it road legal so it can be driven to Malvern :emoji_sunglasses:
Big thank you to all you guys for all your help"
Hope it goes well on the day (especially as I suggested Avonmouth!) Above is a copy/paste from the Kitnet forum from a guy named Mark who had his
RS200 replica tested there this Feb (and re-tested in April when it passed). The only other advice I've heard recently is that apparently the
tester is fond of lemon drizzle cake so if you've been concentrating when watching bakeoff...
