Author: Subject: Brake light height from ground
donut
posted on 12/12/05 at 04:15 PM Reply With Quote
I know the height of the lowest rear light (brake in my case) needs to be 350mm from the ground but is that the middle of the bulb/light or bottom of light itself?
ta
mookaloid
posted on 12/12/05 at 04:20 PM Reply With Quote
I believe it to be the bottom of the lens - I could be wrong though.
I forgot about the minimum height when I fitted my rear lights I had to jack up the rear with the spring adjusters to make sure I got through the SVA
Mark
emsfactory
posted on 12/12/05 at 04:29 PM Reply With Quote
Pretty sure its the edge of the lens for height.
I think it's the center of the lenses for angles of visibility.
donut
posted on 12/12/05 at 04:31 PM Reply With Quote
bugger!
looks like the C spanner will be doing some work tomorrow
Humbug
posted on 13/12/05 at 07:18 AM Reply With Quote
For height/distance from edge or centre it's measured to the edge of the lens
donut
posted on 14/12/05 at 03:37 PM Reply With Quote
Just measured and the bottom edge of the light lens is 135mm. Close or what!!
