Author: Subject: Top Harness Mounts????
rayward
posted on 17/7/06 at 12:03 PM Reply With Quote
does this look OK, or will i have to raise the top mount???
top harness
top harness
top harness2
top harness2
Ray
David Jenkins
posted on 17/7/06 at 12:05 PM Reply With Quote
You'll probably have to do the measurements from the seat to be sure... you might be OK as you've got GRP seats.
On that topic, you'd better put some edging strip round the harness holes, as the tester may take a dislike to that fairly sharp edge.
rgds,
Surrey Dave
posted on 17/7/06 at 12:06 PM Reply With Quote
Depends where they are in relation to the seat squab/ base hieght.
But with unupholstered seats you should be able to wangle it.
mad4x4
posted on 17/7/06 at 12:43 PM Reply With Quote
I'd put edging on the seat hole as it may deemed sharp for the seatbelt and may lead to cutting or chaffing.
Scot's do it better in Kilts.
JohnN
posted on 17/7/06 at 06:39 PM Reply With Quote
The edges of the seat belt shackles themselves were deemed too sharp at Shrewsbury VOSA , could injure somebody if you backed into them. 100mm sphere avoidance measures required to avoid contact
wicket
posted on 18/7/06 at 11:14 AM Reply With Quote
There is a diagram in this thread showing SVA dimensional requirements
http://www.locostbuilders.co.uk/viewthread.php?tid=19802
