Ian D
posted on 28/9/06 at 08:47 PM |
flexible fuel line attachments
Is it ok to use cable ties to attach the flexible fuel lines to the 25mm box sections of the chasis?
Ian
chockymonster
posted on 28/9/06 at 08:50 PM |
I'd say no.
The cable tie will chafe through.
I used rubber lined P-Clips to keep them secure.
RazMan
posted on 28/9/06 at 09:44 PM |
Agreed, P clips would be the better option but playing Devil's advocate here - why would cable ties chafe if they were tightly fixed?
[Edited on 28-9-06 by RazMan]
Raz
DavidM
posted on 28/9/06 at 10:22 PM |
When my car was SVA'd the inspector was telling me that he'd seen some of the rigid brake pipes on a Caterham CSR secured with cable ties.
He felt it was not ideal, but said secured is secured.
I used plastic P clips myself for brakes and fuel and they passed OK, although I used rigid lines wherever possible and kept flexible lines as short
as possible so they didn't need securing.
[Edited on 28/9/06 by DavidM]
Proportion is Everything
chockymonster
posted on 29/9/06 at 09:48 AM |
You're clamping the rubber hose with an inflexible piece of plastic, any movement in the hose may chafe against the cable tie
