HAL 1
posted on 14/11/06 at 05:48 PM |
rear view mirror
Hi, almost ready for SVA, F*****g mirror fell off, previous experience with double sided tape was a waste of time so question is, what can i use to
stick the thing back with ? or will one of those rubber suction ones do the job for test purposes ?
mac1ZR
posted on 14/11/06 at 05:56 PM |
rubber suction one is fine
GOOD LUCK Chris
RazMan
posted on 14/11/06 at 06:19 PM |
I used PU adhesive on mine - it won't come off now
Raz
HAL 1
posted on 14/11/06 at 06:45 PM |
Cheers guys, thanks for the speedy responce, i can sleep easy tonight ( until the next problem arises )
desyboy
posted on 14/11/06 at 07:06 PM |
Do you need a rear view mirror for sva?
Des
posted on 14/11/06 at 08:05 PM |
i believe it is worded that you need one unless it would be ineffective (ie a van), and without one you need a nearside wing mirror.
HAL 1
posted on 14/11/06 at 08:09 PM |
Thanks for the offer desyboy, I've got the actual mirror its just that it fell off and I'm panicing cos I'm close to SVA, I might
try one of those rubber suction types and see how good they are for general use, if it seems ok I'll leave it on for the time being.
thanks again
HAL 1
posted on 14/11/06 at 08:17 PM |
I suppose if it does the job its intended to do then i should be ok its just that i'm getting a bit stressed about things, maybe a little too
much.
Chippy
posted on 14/11/06 at 11:34 PM |
If you pop into your local garage, they will almost certainly have the proper pads that the mirrors are fixed with. Put mine on with one and I recon
you would have to break the glass to get it of. hth Ray
HAL 1
posted on 15/11/06 at 05:17 PM |
Mate agreed with you chippy, said to try a main dealer, dont know why i didn't think of that, maybe its cos i'm a numpty, i think thats
why i possibly misunderstood you desyboy, thought you were asking would i like one, like i said, i'm a numpty
thanks guys really appreciate the info
