RazMan
posted on 2/1/07 at 10:22 PM |
SVA 'toolkit'
OK I have got my SVA test on Monday [oooerrr] so what should I take with me to smooth the way? (apart from bribes)
I know I will take :
1. Rubber edging strip to sort out any forgotten sharp edges.
2. Cable ties to secure any floppy bits
3. SVA pad for my Momo steering wheel (ally spokes)
4. Small toolkit to make adjustments on site (headlight alignment, speedo calibration etc)
5. Some pictures of hidden areas if questioned (tunnel and fuel tank areas mainly) It might save some dismantling, removing access panels.
6. Fuel & brake pipe spec sheet
7. Engine donor V5 to prove engine age
8. Receipts for everything where possible
So what else guys ?
Raz
graememk
posted on 2/1/07 at 10:26 PM |
some food and a few hot drinks, gloves recipts for everything you can think of car related
MkIndy7
Duck Tape... Insulation tape.. Foam... Self Tapping Screws
Cordless drill?
And above all a Friend to help!
We took a second car full of everything we could think of just incase... 1 of you can even nip off and buy things if needed
omega0684
posted on 2/1/07 at 10:27 PM |
a bible?
scottc
Good luck mate. That is one seriously nice looking car.
Hellfire
posted on 2/1/07 at 10:31 PM |
A bag of wire wool to ram up the exhaust should it be too loud
Phil
Bob C
posted on 2/1/07 at 10:49 PM |
few bits of old hose & a carving knife - to tiewrap round radius failures.
Biggest surprise for me was a radius failure on the top seatbelt clips (behind the seat) - these count as exterior projections (and on a car with no
reverse too!!!!!). bizzarrely - the Utrim has since fallen off....
Bob
stevec
posted on 2/1/07 at 10:59 PM |
Pampers
stevec
posted on 2/1/07 at 11:06 PM |
A mate.
Some oil and water,
And the best of luck.
Hope you pass.
[Edited on 2/1/07 by stevec]
RazMan
posted on 3/1/07 at 12:32 AM |
Tee hee some good ideas there
Do I need both fuel tanks full or will just one do? They are isolated by separate taps.
I'm hoping they will allow me to align my headlights with their lighting test setup and calibrate my speedo when on the rollers. I've
heard some testers are really helpful.
Raz
David Jenkins
posted on 3/1/07 at 08:35 AM |
Petrol tank(s) have to be full - but they check with the fuel gauge, so as long as that reads full they won't know otherwise.
Good luck!
oliwb
posted on 3/1/07 at 10:19 AM |
I had to have to SVA's with different guys each time. The first guy was a total arse and won't let me change a single thing. Not even
setup my headlights. Said the SVA was a test and not a time to be able to setup the car correctly to pass....apparently I shouldn't have
presented it till it was correct (what a joke)....second man was a really decent chap. Said he hadn't driven a Tiger so smooth as it (bike
carbs) and even went so far as to say that they were one or two sharp edges that he thought might fail if he tested it but since everything else was
fine he wasn't going to get the radius checker out......even asked me if that was OK......uh yeah! So its hit and miss really. A lot of the
things it failed on first time weren't changed in anyway for the second test and it passed!?! Eg. cable ties, rear boot cover, wheel studs,
exhaust, wiring of hazard light switch (telltale) etc etc etc....and we setup the brake balance, speedo, headlamps, fog lamp etc whilst
there.....Madness....Oli.
PS
Good luck matey its an awesome looking car - very jealous!
flak monkey
posted on 3/1/07 at 10:26 AM |
Good luck!
That'll be tricky on mine cos i dont have a gauge They will have to take the cap off and have a look like i do
Sera
http://www.motosera.com
DarrenW
posted on 3/1/07 at 10:48 AM |
If you use digi dash you will need to prove what max speed it is capable of reading. I took the DD2 pro advert out of a mag.
I set my headlights up at home from first principles and didnt need any adjustment. Quite easy to do, quite hard to type about!
Dont offer your pics of hard to see areas too readily, wait until he has indicated he must see it first. I was a bit to hasty showing him pics of
handbrake mech and had all sorts of probs to sort it out.
posted on 3/1/07 at 10:56 AM |
Although the testers can be a PITA, they'll usually allow some adjusting during the test. At my first test, the examiner was being examined(!)
by the area examiner who was a right stickler for the rules. Came out with all kinds of edicts about what needed to be done to pass (very few had
anything to support them in the manual) but still allowed time for adjustment of the headlights etc.
For the toolkit I'd suggest hot drinks, some food, dry clothing (5 hours in wet clothes is a bit yucky), tie wraps, spanner set etc.
And don't forget the bundle of non-sequential used tenners which might get accidentally left next to the emissions testing machine
chriscook
posted on 3/1/07 at 06:40 PM |
As said by someone else you can do a pretty decent job of aligning the headlights if you park a couple of metres away from your garage door. Was good
enough for my SVA man. I think I'd want to hvae had a go and only make a small adjustment if wrong rather than show up with them way off. In all
likelyhood you'll probably get it right.
As for speedo I was fortunate enough to be able to get my hands on a gps and private roads. If you are driving to SVA can you compare with a GPS on
the way and adjust outside the test centre before you go in???
[Edited on 3/1/07 by chriscook]
RazMan
posted on 3/1/07 at 06:56 PM |
I've just been having a go at adjusting my lights tonight. I parked SWMBO's CRX on the drive (about 20 metres from the garage door) and
stuck masking tape on the beam cutoff points. I then parked the GT in exactly the same position and adjusted the lights to the marks - seemed to work
well and I am fairly sure they are about right now.
As for the speedo, I did some rough calibration on the rollers last month so it wont be too far out, but hopefully I can tweak the Evodash on the
day.
BTW I have been told by Aeon that you are not allowed to drive to an SVA test any more I have not heard this anywhere else though, but I am
trailering the car down anyway (more for safety reasons really)
Raz
DIY Si
posted on 3/1/07 at 07:02 PM |
Unless they've changed the rules again (! ) you can drive to it still. If you trust it to be road worthy why not do it? Give you a chance
to bed the brakes in if nothing else. And why miss the chance to drive a totally unregistered/unmarked car on open roads?
[Edited on 3/1/07 by DIY Si]
Sun Tzu, The Art of War
flak monkey
posted on 3/1/07 at 07:06 PM |
Last time i enquired officially with my insurance company (september this year) it was still perfectly ok to drive to SVA insured on the VIN number. I
think it varies between insurers, so just check!
Sera
RazMan
posted on 3/1/07 at 09:14 PM |
I've got 60 miles to get to my SVA Chelmsford (my nearest) has shut down for 6 months and Gillingham is my second choice as they have already
passed some Aeons and are familiar with their design so are less likely to rip mine to shreds.
As I have already mentioned, I am prepared for a fail first time around and I would rather have a thorough check by a professional to make sure
everything is safe before I risk life and limb on the M25 I didn't get the chance to do some shakedown tests at my local airfield so the car
has never turned a wheel on the road, although it did 42 miles on the rollers last month during the mapping session and used over 20 litres of fuel
(which I couldn't believe)
If driving to SVA IS ok I will certainly do this for the re-test when I have tax & insurance -
Raz
DIY Si
posted on 3/1/07 at 09:18 PM |
How will you have tax and insurance for the re-test? You won't have any tax yet! Fair enough if you've not had a chance to give it a blat
yet though
RazMan
posted on 3/1/07 at 09:26 PM |
Ah ......... just testing to see if you were awake?
Raz
DIY Si
posted on 3/1/07 at 09:51 PM |
WooHoo, it would appear I am then!
