Author: Subject: sva
dilley
posted on 13/4/07 at 10:31 PM Reply With Quote
sva
will I need a cat for sva??even if I get allocated aq plate? engine is 98.
pajsh
posted on 13/4/07 at 10:56 PM Reply With Quote
Yes.
SVA emmisions test is based on the age of the engine and 98 is well after the cut off date around 1 Aug 92 IIRC.
98 will certainly need a cat.
MOT emmisions tests come 3 years after registration so lots of people fit cats just for the SVA.
[Edited on 13/4/07 by pajsh]
I used to be apathetic but now I just don't care.
dilley
posted on 13/4/07 at 11:01 PM Reply With Quote
chances are I will be on a q pllate.
pajsh
posted on 13/4/07 at 11:19 PM Reply With Quote
SVA section 18
Pre 75 - Visual
1 Aug 75 - 31 Jul 86: 4.5% CO, HC 1200
1 Aug 86 - 31 Jul 92: 3.5% CO, HC 1200
Post 1 Aug 92: 0.3% CO, HC 200 plus lambda & idle tests (i.e. CAT required)
Based on the "effective date" which is the date the vehicle was manufactured or for a re-built car is "1 Jan preceeding the year in which the engine was maufactured"
Q plate or Age related plate comes after SVA but does determine the MOT test.
So if your engine is 98 you will need a cat to meet the much tougher standards listed above post Aug92
zxrlocost
posted on 14/4/07 at 08:26 AM Reply With Quote
CAT YES FOR SVA
posted on 14/4/07 at 11:19 AM Reply With Quote
But I see the OP is using a '98 engine so YES!!!!!!
Hellfire
posted on 14/4/07 at 08:23 PM Reply With Quote
Originally posted by stuart_g
I thought it was Aug '95 when the emissions changed, that's why everyone goes for a pre '95 engine or am I mistaken?
No, you're not mistaken. Post 1st August 1995 engines are tested on stricter emissions.
Phil
[Edited on 14-4-07 by Hellfire]
