Author: Subject: demister
rell
posted on 22/9/03 at 10:05 AM Reply With Quote
demister
For the sva you need to have a demister on the windscreen.
Im going to be having a flat bottomed locost so the engine bay is going to be sealed.
can i duct the air from the engine bay up infront of the windscreen and say that will demist the windsreen (which it would i think?)
will this idea pass the test or not and has eney one tryed it.
timf
posted on 22/9/03 at 10:24 AM Reply With Quote
the sva demist requires that the screen has enough air to clear it and the test is done statically so unless you plan to have a fan assist it won't pass
rell
posted on 22/9/03 at 11:00 AM Reply With Quote
dam heated screen it is
timf
posted on 22/9/03 at 11:11 AM Reply With Quote
why not try one of the small lecy demister blowers
blueshift
posted on 22/9/03 at 11:32 AM Reply With Quote
If we go for a windscreen I'm definitely looking into electrical demisters after what happened to hicost..
put the fear of water into me.
flyingkiwi
posted on 22/9/03 at 12:04 PM Reply With Quote
the little lecy demister's you see in those cheap mail order catalogues are great. Stuck them in my friends mini and they demisted the windscreen in seconds. Beats waiting for the engine to warm up before they work.
I've thought about ducting air from around the exhaust manifold too, so when your moving you can switch the heaters off.
It Runs!!!!! Bring on the SVA!
locoboy
posted on 22/9/03 at 12:27 PM Reply With Quote
Hmmmm, dodgy ground ducting engine bay air into the cabin,
Leaky manifold = Sleepy = crash
Colin
Locoboy
posted on 22/9/03 at 01:22 PM Reply With Quote
Be o.k. in a locost though, no roof.
yours, Pete.
Simon
posted on 22/9/03 at 01:37 PM Reply With Quote
Colin,
"Hmmmm, dodgy ground ducting engine bay air into the cabin"
It's how they did it on aircooled cars - just ensure manifold is sound, make a box around it with a fresh air supply (external) and some sort of blower!
Call it a heat exchanger
Simon
locoboy
posted on 22/9/03 at 01:51 PM Reply With Quote
Pete, if soft enought to want a heater then a roof has sure to follow suit!
I come from the land where the men wear skirts and no undercrackers, we know what cold is, no heaters for us must ba a southern jessie thing going on!
Locoboy
Mark H
posted on 22/9/03 at 02:43 PM Reply With Quote
1. Go to SVA with no windscreen at all.
2. Pass SVA.
3. THEN worry about screen, demisters, wipers, squirters, etc!!
You never know, you might like it windowless (get a helmet though!!), or grab an areoscreen (£20).
Mark Harrison and
Q986 KCP back from the dead...
blueshift
posted on 22/9/03 at 03:06 PM Reply With Quote
With an aeroscreen, do you still get rocks and bugs in your face?
Simon
posted on 22/9/03 at 03:08 PM Reply With Quote
My aerosreen is attached to my bashhat so s/be ok
Simon
rell
posted on 22/9/03 at 03:40 PM Reply With Quote
what is a lecy dimister?
sound a bit poo coming avon or littlewoods
rell
posted on 22/9/03 at 03:43 PM Reply With Quote
Had an idea would tape heating work if you run it along the bottom of the windscreen to heat up the glass ?
Simon
posted on 22/9/03 at 03:57 PM Reply With Quote
Rell,
Basically it's a 12v hairdryer that a) runs off electricity rather than using hot water, and b) looks nothing like a hairdryer.
Simon
James
posted on 24/9/03 at 10:53 AM Reply With Quote
Originally posted by Simon
Rell,
Simon
Car Builder Solutions do one for about £24
It's about 6-8" wide so may need some ducting to clear entire screen- or a second one!
HTH,
James
Mark H
posted on 24/9/03 at 11:19 AM Reply With Quote
Blueshaft
You do indeed (I wear a helmet for that reason plus the tears you get over 50 mph make you blind!), but suspect you would with a full screen anyway.
Mark Harrison and
rell
posted on 24/9/03 at 12:58 PM Reply With Quote
where do i get one of these gloryfied hairdryer from ?
James
posted on 24/9/03 at 03:23 PM Reply With Quote
Look up 3 posts...
James
