Author: Subject: 4 point harness eye bolts
givemethebighammer
posted on 13/11/03 at 11:08 PM Reply With Quote
My 4 point harness eye bolts have no markings to indicate their strength (i.e. 8.8 etc)
Are all of these type of bolts a particular rating (like cap or dome headed ones).
Or does the fact that an eye bolt has been designed for this type of purpose, so is just assumed to be up to the job ?
Just wondered what Mr SVA thinks
Hugh Paterson
posted on 13/11/03 at 11:16 PM Reply With Quote
GMTBH
You can buy eyebolts that show their strength indicated/stamped on the side, a
typical indication for load would be SWL. (Safe working load). The test weight however is usually shown as well and is of course a lot higher. If you buy from a reputable ironmonger he should be able to supply a forging certificate/tested load details where did u get yours from?
Shug.
givemethebighammer
posted on 13/11/03 at 11:25 PM Reply With Quote
they came with my "Luke" 4 point racing harnesses. so they should be pukker items
Hugh Paterson
posted on 13/11/03 at 11:29 PM Reply With Quote
No worries then, if the SVA inspector queries them show him the receipt, assuming of course its an "approved harness" which it is
ta ta the noo
Shug.
givemethebighammer
posted on 13/11/03 at 11:35 PM Reply With Quote
Mind you I can just see it. The inspector saying "how do I know that the eye bolts came with the harnesses, I can't see any eye bolts on the receipt". No I think I will go buy some marked ones just to be safe.
so 8.8 or 12.9 ?
thanks
posted on 14/11/03 at 12:20 AM Reply With Quote
i've heard they need written proof that the bolts are compliant...
cant see how eye bolts are used, wouldnt work with mine, i'm just using normal bolts to hold the belt down.
marshall
posted on 14/11/03 at 07:30 AM Reply With Quote
i thought that the 4 point harness
are not sva aproved that what i was told
by some tiger builders is this true?
or is it just the eye bolts that are not
stamped with 8.8 on?
Ben_Copeland
posted on 14/11/03 at 09:06 AM Reply With Quote
Never heard that one..... i know loads of people with 4 point harnesses, that have passed the sva !!
Ben
Locost Map on Google Maps
Enter Your Details Here
posted on 14/11/03 at 09:49 AM Reply With Quote
yeah, how can they moan if it is suitably quick releasing?
Ben_Copeland
posted on 14/11/03 at 11:57 AM Reply With Quote
Well there isn;t any difference between the 3 and the 4 point harness, except the 2 shoulder straps come together at the mounting, instead of mounting separately. The strap bit that keeps it all together is the same. So i cant see any reason what-so-ever in 3 being allowed and 4 not.
Think someones been pulling your leg marshall !
[Edited on 14/11/03 by Ben_Copeland]
Ben
givemethebighammer
posted on 14/11/03 at 12:13 PM Reply With Quote
Just spoke to Luke Harnesses and have been assured that their have been very few SVA issues with their harnesses. They said that the harnesses and eye bolts are very over engineered. Also added that if Mr SVA queried on the test we could call them (Luke) and get the inspector to talk to their engineers.
Marcus
posted on 14/11/03 at 09:30 PM Reply With Quote
The issue with the harnesses and
SVA has always been down to the type of buckle used, not wether they're 3 or 4 point.
There are 3 (as far as I know) types of buckle - road, off road and FIA spec.
the latter two employ a twist function to release which is not e rated and technically is illegal for road use (haven't seen many rally drivers get nicked though). The former is a push button release like a normal seat belt - this type has no problems with plod or SVA, just make sure the wabbing has e marks.
Marcus
Marcus
Because kits are for girls!!
ChrisW
posted on 15/11/03 at 09:03 AM Reply With Quote
Have been told the same as Marcus reports - it's all in the release system.
Example - I've got 3 point harnesses with 'conventional' releases (the same as normal seat belts) in my Fez and have had no problems with MOT. Well, not about the belts anyway! I did have a copper pull me over having seen the old belt hanging up in the window. He got a few words into a 'not wearing seat belt' lecture before he noticed the harnesses!
Chris
My gaff my rules
bike_power
posted on 15/11/03 at 02:49 PM Reply With Quote
I've just had my Dax SVA'd and although it didn't pass (expected) the examiner didn't question the eye bolts or the 4 point harness with the aircraft style twist release buckle.
Dax did say that some examiners ask to see proof of the eye bolt strength but I've not heard of that recently.
greggors84
posted on 16/11/03 at 01:45 AM Reply With Quote
On my Luke 4 Points i have bought, a couple have 8.8 stamped on them and some dont. Ill use the ones that say it on the bolts they can see.
Chris
The Magnificent 7!
