Author: Subject: Jerry can as a fuel tank.
Jesus-Ninja
posted on 6/9/08 at 06:55 AM Reply With Quote
I was thinking about buying a new jerry can and welding on a second spout. I'd then hook one spout up to a filler (in the same way as the pouring spouts attach) on the outside of the car and the other spout would be modified to recieve a cap with fuel lines running through. Both spouts would be attached to thier "bits" with the usual jerry can type fitting, and locking pins.
The can would be located in the usual SVA compliant location: outside of the cabin, out of direct impact, sharp bits, and not in contact with anything that would rub etc etc.
Seems that they are a nice size, ready made, and if done properly, could satisfy the MOT, but also allow for rapid changing of the tank at track days for full normal jerry cans (ie you don't need the second spout for filling up.
Just a thought
Suspension geometry tool here >>> http://www.locostbuilders.co.uk/viewthread.php?tid=81376
speedyxjs
posted on 6/9/08 at 07:17 AM Reply With Quote
Thats a really good idea
v8kid
posted on 6/9/08 at 08:03 AM Reply With Quote
I used to use 5l plastic petrol cans in my racing hovercraft with all the connections via the cap so refueling was a simple swap of body. Used a clam buckle and strap to hold it in.
Only mods required were a couple of holes in the cap and some fittings
Would like to claim the idea as original but I pinched it from the outboard motor guys!
Works well.
britishtrident
Have you looked at outboard motor fuel tanks ?
mark chandler
posted on 6/9/08 at 08:15 AM Reply With Quote
My mate used to race with one, no problem at all with this. He place it upright and used the standard filler, just stabbed a couple of holes in for fuel in/out and breather.
Boat tanks also get used and are nicer as above as designed but of course do cost more.
Regards Mark
posted on 6/9/08 at 08:36 AM Reply With Quote
It will not pass SVA or MOT if it looks removable though, it must be firmly bolted in. You will have to make the second lid look more permanent if it's holding the connections to the fuel and return. By the time it is done it will still be quicker to pour the fuel in out of another jerry can, how many tanks are you thinking of using on the track day?
[Edited on 6/9/08 by Peteff]
v8kid
posted on 6/9/08 at 10:04 AM Reply With Quote
Mine passed the SVA with only 2 webbing straps and clamshell buckles holding it in
Jesus-Ninja
posted on 6/9/08 at 10:06 AM Reply With Quote
Maybe as an "option" for post SVA then
How much fuel? Well, at the ring I was getting about 6 or 7 miles to the gallon which is, as it happens, 6 or 7 laps to a 60 litre tank.
A 20 litre tank would give me a couple of laps....
Mark G
posted on 6/9/08 at 10:24 AM Reply With Quote
baffles?
posted on 6/9/08 at 11:59 AM Reply With Quote
Jesus-Ninja
posted on 6/9/08 at 12:31 PM Reply With Quote
Originally posted by Mark G
baffles?
Good point. I've not seen any baffled jerry cans...
v8kid
posted on 6/9/08 at 02:03 PM Reply With Quote
Hmm nice straps they will become a must have accessory for the boys at the drag strip.
