Krismc
posted on 16/4/09 at 03:02 PM |
Too much toe out?? will i fail
ive had to toe out quite a lot to self center- will i fail for this??
Ben_Copeland
posted on 16/4/09 at 03:06 PM |
I'm guessing no, as long as it still drives ok
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
blakep82
posted on 16/4/09 at 03:17 PM |
wheel alignment isn't part of the test is it? i don't think it is... if its not, then you should be fine. if my tracking was 8mm out
yesterday, and i didn't realise, i don't think it'll be an issue
________________________
Davey D
posted on 16/4/09 at 03:35 PM |
has your VortX got Sierra, or Cortina front end?
when MNR heard i had failed on no self centering they told me that none of their other cortina based front ends had failed on self centering
before...
now i dont know if that means none have failed with correct toe / tyre pressures or not ?!?
posted on 16/4/09 at 03:44 PM |
The only dynamic test the car goes through is self-centering so as long as it passes that, then there's no problem!! You can have stupid amounts
of toe-out making it drive like a dog but as long as it passed self-centering there's not much they can fail you on re dog-like handling!!!!
tomprescott
posted on 16/4/09 at 03:59 PM |
As far as I'm aware it needs to self centre and have the wheels covered, so it shouldn't make a difference to you, only way I can see it
causing problems is if you put huge spacers on the back that pushed the wheels out past the arches....
marc n
posted on 16/4/09 at 06:30 PM |
hi chris with the correct castor you dont need any weird stuff especially not big toe out whats your castor set at ???
cheers
marc
please email rather than u2u
chrismnrltd@btinternet.com
marc n
posted on 16/4/09 at 06:31 PM |
tyre pressures should be 16 front 18 rear
cheers
marc
