chris_harris_
posted on 18/4/09 at 09:22 AM |
SVA Fail Birmingham
As the title, and i didn't expect to pass on some things anyway, as i had not adjusted mixture. reading were CO 1.15. HC 3706 and Lambda 1.424.
think its a bit rich!!
Failed on a few radius bits which is fine.
Ignition Key needs moving to within the 127 mm area.
It self centred which was a surpsise,as i had not set any geometry at all really.
Wilwood Brake valve not locked. Thinking of just removing it, but then i may be over braked at the back, as i have sierra discs at the bak and Cortina
Fronts. What does everyone think on this?
And speedo way out, but thats me not using the speedo healer correctly.
Will put in for a re test sometime in the nest few weks i think. They did say they have no work after 28th April. Funny that!!
Regards Chris
dave-69isit
posted on 18/4/09 at 11:17 AM |
sva test
not a bad fail
scotlad
posted on 18/4/09 at 08:29 PM |
Och thats not bad at all- you'll be on the road in no time!
Wonderous is our great blue ship that sails around the mighty sun, and joy to everyone that rides along!
adithorp
posted on 18/4/09 at 11:19 PM |
Lambda over 1 is weak, under is rich. Any air leak on the exhaust will also push lambda high. Also do a search on recent posts SVA/emmisions posts re
getting the cat hot enough.
adrian
http://jpsc.org.uk/forum/
