eznfrank
posted on 1/6/09 at 11:59 AM |
IVA fuel tank protection requirements
Just looking through the IVA manual and I doubt my Indy with the fuel tank already in place would have much luck passing the rear impact into
petrol tank part of the test. Currently the only thing rearward of the tank is the mounting rail for the rear panel an dthe panel itself.
Not sure how best to sort this. I was thinking of making a second rail to go above the tank and a couple of vertical pieces into the rear panel
mounting rail or do we think IVA man will want to see a solid panel? The rules not very clear IMO.
blakep82
posted on 1/6/09 at 12:14 PM |
i think a 2nd rail with vertical bars will be fine. its got to be stronger than a sheet of steel.
thats how mine is anyway
________________________
handyandy
posted on 1/6/09 at 12:15 PM |
hi, just reading the manual & can,t find the section relating to the fuel tank protection from rear impact, which heading is it under please?
cheers
andy
200mph
posted on 1/6/09 at 12:19 PM |
Hope I haven't misinterpreted - could this be done by a horizontal bar between roll bar supports (mine will go into the rear corners)?
If it isn't broke, fix it until it is
blakep82
posted on 1/6/09 at 12:22 PM |
9.
Fuel Tanks must be positioned so as not to be vulnerable to damage from protruding parts or sharp edges in the event of a front or rear impact.
is all it says... hmmm. a bit vague really.
steel plate could be punctured, and additional bars could bend, break and poke sharp edges at the tank...
[Edited on 1/6/09 by blakep82]
just thining, has anyone actually failed IVA on fuel tank protection yet?
just thinking, it could mean as long as you've got no corners of brackets pointing right at the tank, or long bolts through the chassis pointing
at it then it might be fine?
i mean, you you get hit hard enough it will burst the tank, no matter what you do to it
twybrow
posted on 1/6/09 at 12:38 PM |
Try this thread
I posted a few comments made by my SVA tester a few weeks ago....
oldtimer
posted on 1/6/09 at 12:39 PM |
This did atract some discussion a while back and I think we came to the conclusion that as long as there were no 'protruding parts or sharp
edges' on your vehicle you were OK. I guess this till needs testing by IVA test itself - anyone here had this examined under IVA rules yet??
eznfrank
posted on 1/6/09 at 12:42 PM |
I've got a feeling it won't be a problem but once the rear panel is on I really don't want to have to take it off again!!!
blakep82
posted on 1/6/09 at 12:43 PM |
quote: Originally posted by twybrow
Try this thread
ah, yea, thats what i was thinking
blakep82
posted on 1/6/09 at 12:44 PM |
have you got a picture of your rear end? (you know the one i mean )
eznfrank
posted on 1/6/09 at 12:55 PM |
No I don't think I have. Basically the bottom of the tank is "protected" if you can call it that by the rear rail but the top rear
most edge has nothing rearward of it other than the fibreglass panel.
blakep82
posted on 1/6/09 at 01:10 PM |
from what the other thread said about the iva man, that should be alright, as long as you've not got any bolts through the rear panel
eznfrank
posted on 1/6/09 at 01:15 PM |
Mine is very similar to this>>>
http://locostbuilders.co.uk/photos.php?action=showphoto&photo=DSC01870.jpg
[Edited on 1/6/09 by eznfrank]
blakep82
posted on 1/6/09 at 01:38 PM |
i can see your concerns, but given there's no part of your car behind it that would cause damage it should be fine i think.
my car as 3 horizontal tubes accross the back, with vertical tubes, all 2" round, so i've got no worries coz i'm covered all round,
but i should think yours will be fine
twybrow
posted on 1/6/09 at 02:07 PM |
From what my SVA tester said, that will be fine....
big_wasa
posted on 1/6/09 at 03:05 PM |
Mine is bassed on a gts and the book. So no rear metal work.
Ive modified mine this week end as I dont want to have to take the panel of once glued on.
Does any one feel I need to brace it forward to the rear bulk head for the iva ?
martyn_16v
posted on 1/6/09 at 08:37 PM |
Adding tubes can't hurt, but they're not going to stop any protruding things from another vehicle hitting the tank in an impact (other
than the highly unlikely direct hit to one of the bars).
How long until the first IVA inspector decides you need a 4mm steel plate there. That'll make a loud clang when it falls off on the way home
