Author: Subject: sidelight tell tale
gavin174
posted on 8/5/10 at 05:19 PM Reply With Quote
sidelight tell tale
I am sure i read somewhere you now need a tell tale for sidelights..
is this correct?
if so what colur does it have to be.
Thanks Gavin
eznfrank
posted on 8/5/10 at 05:40 PM Reply With Quote
a tell tale light or sticker? IIRC you don't need a light but there must be tell tale on or in the vicinty of the switch. Best check the book!
speedyxjs
posted on 8/5/10 at 06:04 PM Reply With Quote
Yes you do
gavin174
posted on 8/5/10 at 06:15 PM Reply With Quote
cheers speedy..
sort one problem and find another...
wasnt aware sidelights had to work with ignition off..
have to rewire them now them...
one step forward.... and all that.
Madinventions
posted on 8/5/10 at 08:24 PM Reply With Quote
Can you just wire your speedo backlight into the sidelight circuit?
View my band website:
http://www.shadowlight.org.uk
russbost
posted on 9/5/10 at 08:58 AM Reply With Quote
"Can you just wire your speedo backlight into the sidelight circuit? " - Yes, believe that is an alternative, but not all speedos have a separately fed backlight - many are permanently o with ignition.
