marc n
posted on 27/5/10 at 08:36 AM |
latest version of iva manual
hi all a quick heads up on the latest version of the iva manual , although it still says version 4 it is version 5 update.
page 84 has the information, basically a sticker will need to be attached in the area around the bias adjuster with the wording in note 6 . i am
having some made , cost to anyone who needs one is £2.50 plus the cost of a stamp
new manual found here
www.businesslink.gov.uk/Transport_Theme_files/124_IVA_M1_Inspection_Manual__Version_4_0510.pdf]new manual[/url]
best regards
marc
[Edited on 27/5/10 by marc n]
please email rather than u2u
chrismnrltd@btinternet.com
iank
posted on 27/5/10 at 08:44 AM |
Interesting stuff, good to see VOSA apply common sense to their rules.
Working Linky -> New Manual
Anonymous
cd.thomson
posted on 27/5/10 at 08:47 AM |
Hi Marc,
I don't suppose you could clarify if the new version applies to people attending for a retest?
I failed last week and will be retesting in the next couple of weeks - I'm wondering if I need to alter anything that passed first time.
Craig
big-vee-twin
Nice one was wondering how to deal with the bias bar
The link above doesnt work here's one that does
Link
http://www.triangleltd.com
wicket
posted on 27/5/10 at 08:48 AM |
Just down loaded the new version from your link. Where does it say that a sticker needs to be attached in note 6?
iank
posted on 27/5/10 at 08:50 AM |
quote: Originally posted by cd.thomson
Hi Marc,
I'd call the test station to confirm, I believe you get tested on the regs that existed at the first test by default but worth a phone call.
Anonymous
iank
posted on 27/5/10 at 08:51 AM |
Item 27
Anonymous
marc n
posted on 27/5/10 at 08:56 AM |
best bet is to check with your local testing station but they can only check your car on the failed items on the retest. so any updates wont affect
you, unless of course one was the bias setup in which case i would speak to the tester and ask him how it affects you
best regards
marc
p.s thanks for the help with the link
speedyxjs
posted on 27/5/10 at 09:29 AM |
Is the sticker the only update?
minitici
posted on 27/5/10 at 09:36 AM |
Looks like the requirement applies from August 2010.
" Requirements relating to vehicles fitted with twin master cylinders have
been amended and added requirement to label accordingly from 2/08/2010.
27. Vehicles fitted with adjustable twin master cylinders that have been
rendered inoperable by mechanical means to comply with RS 26
must have a label affixed on the master cylinder or the immediate
vicinity with legible text as detailed in note 6.
Note 6: Adjusting front/rear brake bias may invalidate approval and
breach Construction and Use requirements. "
40inches
posted on 27/5/10 at 10:45 AM |
Also looks like the bias bar no longer has to be welded, a pin or lock wire are once again acceptable
"Note 5: Bias bars and other mechanical adjusting devices fitted to twin master cylinders must be rendered inoperable by mechanical means
e.g. lockwiring of components."
