scoobyis2cool
| posted on 18/9/04 at 03:31 PM |
Indy SVA suspension settings
I'm sure i've seen this thread before but after much searching I've drawn a blank so here goes...
Got my SVA a week on Monday (yikes!) but have yet to do any setting up of my suspension, so I was wondering what the best settings are to get the
required self centring etc?
Also, has anyone got any tips for setting up without special tools? (I've got the usual spirit level etc)
Pete
jacko
posted on 18/9/04 at 04:32 PM |
suspension set up
Hi-Pete - I was advised by MK's Snoopy to put the hole in the mushrooms to the front of the car - have the top of the wheels one degree in
camber and the tracking at 0 degrees this is for after the SVA but for the SVA have the tracking so the wheels are looking outwards at the front of
the car - this helps with self centering and my car passed ok with this setting ps. hope snoopy doesn't mind me passing this info on. Jacko
scoobyis2cool
| posted on 18/9/04 at 05:03 PM |
Thanks Jacko, I'll use those settings and see how I get on, as long as it passes SVA that's fine, then I can fiddle about with it a bit
more afterwards to get the handling sorted.
How can I measure the tracking without specialist equipment? I was going to use a spirit level against the wheel for camber but hadn't figured
caster out yet.
Also, any advice for rear camber?
Pete
givemethebighammer
| posted on 20/9/04 at 09:59 PM |
this will help you do your camber
http://toolspot.co.uk/product/dial-angle-finder-with-magnetic-base
a gunsons trakrite (about £60) will do the toe / tracking
you can do toe setting with string and various combinations of bit of wood / nails / spirit levels etc
i.e.
http://www.mindspring.com/~martinwhite/fiero/tools.html
but for £60 the trakrite got my vote - easy to use and always there when you want it.
and good a good old plumb line will help you do your castor settings (if you can adjust them)
