killerferret666
posted on 30/8/14 at 12:26 PM |
Pre IVA photos - Pic Heavy
First off I covered the exterior previously. (Thread below) Anything new spotted please post in this thread.
http://www.locostbuilders.co.uk/forum/4/viewthread.php?tid=193143
couple things not put on or questions I already have;
* centre of steering wheel - right sod to get off so will go on once i'm happy with everything it will go on
* 2 buttons for ODO to left of steering wheel, do I need to label these as they didn't come with any labels?
* The extra throttle cable at the multiplier by fuel tank, I haven't trimmed because I have no Cable caps. Should I remove the excess or fine
how I've wrapped it up.
Building DDR GT4
Miami Gt4 Blog - Click Here
ceebmoj
posted on 30/8/14 at 01:05 PM |
quote: Originally posted by killerferret666
You might want to put a radius on the bracket on the door, rather than the sharp point.
Jenko
posted on 30/8/14 at 02:33 PM |
I would revisit your brake line securing.......one pic, I can't see any clips holding the lines.....
MY BLOG - http://westfieldv8.blogspot.co.uk/
killerferret666
posted on 30/8/14 at 02:42 PM |
Cheers guys, I've altered radius on door part.
I know which pipe your on about because when I saw the pic with the T piece, I was thinking have I missed it, but I went and looked and the distance
of that pipe is 200mm and is solid as a rock and going nowhere. Glad I'm spotting same thing):.
I actually used the 300mm as a maximum for brake pipes throughout the car as well and securing more where nessacary.
Building DDR GT4
AndyW
posted on 30/8/14 at 08:45 PM |
Brake fluid reservoir needs label like this http://www.kitspares.co.uk/index.php?route=product/product&path=43_9&product_id=79&car=43
killerferret666
posted on 30/8/14 at 09:27 PM |
Cheers Andy, isn't the covered by the caps with the symbol on? Or does it need a seperate label as well.
Forgot to put cheers for link, I'll print two off to stick on anyway...better safe then sorry!
[Edited on 30/8/14 by killerferret666]
Building DDR GT4
The Black Flash
posted on 30/8/14 at 09:47 PM |
"An indelible label must be affixed in a visible position within 100
mm of the filling ports of the fluid reservoirs to ensure that it is
possible for the end user of the vehicle to identify the brake fluid
used in braking system. DOT fluid references and/or the Symbols
and text in table 1 are considered acceptable. "
But I'm pretty sure that label moulded into the caps will count!
Your spare cable is probably ok, but I'd put a cable tie around it rather than just tape. Or if you've a soldering iron, just cut to
length and put a drop of solder on the end to stop it fraying. There are no edge requirements in the engine bay so you don't need a cap anway,
but you could use a blob of silicone etc if you were worried. It would look neater cut to length I think, and neatness helps with first impressions.
