adam_moore
posted on 22/4/05 at 06:36 AM |
Hazard Rules
Hazard Rules
I was reading through my SVA manual last night regarding hazard warning which basically says that it must illuminate all the direction indicators at
the same time and have a tell tale warning light. If I have 2 seperate switches for my indicators (i.e. one on each side of the wheel, then it i
activate both of them, all the indicators will be on......what do you think.....will it pass.
In terms of warning lights, each direction would have a flashing light and with the hazards on both would flash....
Your thoughts would be much appreciated.
Cheers.
Snuggs
posted on 22/4/05 at 07:29 AM |
IIRC hazards must be operated from a single independent switch and have a red warning light with the correct marking.
Clive
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
NS Dev
posted on 22/4/05 at 07:31 AM |
The manual does not specifically say you can't do what you want to do, but I very much doubt it would pass.
Look at it as if the car was sold to someone who didn't know it, they wouldn't know how to put the hazards on in an emergency. Use the
switches as you suggest but just add a separate hazard switch with a built-in telltale, then you can't go wrong. ( I am using a Peugeot switch)
posted on 22/4/05 at 08:58 AM |
Join the 2 switches lives with another illuminated one in the middle for the hazards.
