omega 24 v6
posted on 23/2/08 at 02:06 PM |
Exhaust
OK does the exhaust need to have all it's joints fully gas tight?? does it need to have all joints clamped??
My system seems to fit well together 4> 2 >1 with nice fitting slip joints and a bolt on gsxr silencer. The bracket for the silencer is the only
thing stopping all the joints from slipping rearwards. It is more than up to the job IMHO and i'd like to keep the clean lines of no clamps if
possible.
I'll try and post piccies later as camera is flat.
Guinness
posted on 23/2/08 at 02:30 PM |
My 4-2-1 has springs which hold in under tension. After a couple of heat / cool cycles it is as good as welded tight!
HTH
Mike
Schrodinger
That's how my Cat exhaust went together but I did use CLEAR silicone sealant on the pipes to get a gas tight fit. The pigment in coloured
sealant will burn but as there is none in clear it will not.
Keith
Aviemore
DarrenW
posted on 23/2/08 at 09:26 PM |
Ive used clear silicon to seal my stainless system too. Needed a clamp though. Mikalor clamps are rather good looking imho.
For SVA you have to take care with the end of the stud. I fitted bolt cover.
