johnwilders
posted on 24/7/12 at 10:43 PM |
sorry scrub my last spoutings You need smaller cylinders not lager ones and you have lager drums than me, if you have the larger cylinders fitting the
smaller ones would be a simple cheap fix.
owelly
posted on 24/7/12 at 10:58 PM |
My Altas axle had discs on and to circumnavigate the rears locking-up before the fronts, I chopped half the friction material off the pads so the
contact area was smaller. Can you munch some off the shoes or fit narrower ones?
http://www.ppcmag.co.uk
Daddylonglegs
posted on 25/7/12 at 10:17 AM |
@neilp1 - The hose I used was from either CBS or Europa at Stoneleigh last year, I can't remember which. It is the canvas-type stuff with a
wire-wound inner, no markings. I am waiting on a call from the tester to clarify whether he needs marked pipe and/or paperwork to state it is fit for
fuel use.
The stick-on cable tie holders are a defo no-no I'm afraid. He said that they are liable to 'weather' and come off over time.
@owelly - I always thought that discs were much better than drums hence discs on the rear of mine would make the matter worse?
I see what you are saying about 'adjusting' the brake shoes on the rear, but am worried about reducing the performance too much so it
fails the brake test on serevice brake efficiency at the rear?
I am also going to speak to the tester regarding using bias valves and the rulings as they interpret it on using disabled 'adjustable'
types.
JB
johnwilders
posted on 25/7/12 at 12:47 PM |
If I remember my tech days correctly, “Friction is independent of surface aria ” The size of the brakes is more to do with wear & heat dissipation
than efficiency , for less efficiency you need less pressure, either a regulator or smaller wheel cylinders.
renetom
posted on 25/7/12 at 03:49 PM |
filler hose
Hi
I have a piece exactely 6" long left over, its 51mm I/D 60mm O/D
Ultra flexible fuel filler hose with embedded spiral wire
Part no #FFF51 from car builders solutions. page 37 on their catalogue.
Your welcome to it FOC , UTU.
René.
Daddylonglegs
posted on 25/7/12 at 05:13 PM |
Hi René,
Thanks for the offer, but I need 57mm ID and that looks like the stuff I already have so they would probably not be happy with it anyhow.
JB
emwmarine
posted on 27/7/12 at 08:01 PM |
JB
So when running the loom across grp, such as under the wheel arches to the rear lights, how do you attach the loom to the grp? Don't want to
rivet through grp panels.
Building a Dax Rush.
johnwilders
posted on 27/7/12 at 09:36 PM |
I used PU all the way along
Daddylonglegs
posted on 28/7/12 at 07:24 AM |
^^^^^ +1
I used Tigerseal to stick the pads to the inside of the arch then tie-wraps to hold the loom. Works a treat, it ain't gonna move
(famous last words )
emwmarine
posted on 28/7/12 at 04:02 PM |
PU?
loggyboy
posted on 28/7/12 at 04:26 PM |
Polyurethane
(ie sikaflex, tigerseal)
Mistral Motorsport
Bizarro
posted on 7/8/12 at 10:41 AM |
types.
JB
Hi
Did you get any feedback re bias valves and IVA?
My car is pre IVA and I have fitted an adjustable Willwood Proportioning Valve on the rear brake lines, after reading a few posts on here I was
looking at removing it before the IVA, but obviously due to rear locking I would rather leave it if it is IVA compliant if locked!!
