Author: Subject: side lights
RickRick
posted on 3/12/08 at 07:49 AM Reply With Quote
side lights
I've got my side lights wired up to come on with the accessory switch on my ignition, so i can turn the key backwards, away from ignition on, to switch them on, but i can't then remove the key, will mr sva like this?
dogwood
posted on 3/12/08 at 08:00 AM Reply With Quote
Probably not
FREE THE ROADSTER ONE…!!
Mr Whippy
posted on 3/12/08 at 08:02 AM Reply With Quote
don't think so as you are meant to be able to leave your side lights (parking lights) on at night without the key in the ignition so most likely that is a fail, wire the car as per a modern production car behaves and you will be fine
[Edited on 3/12/08 by Mr Whippy]
blakep82
posted on 3/12/08 at 08:15 AM Reply With Quote
i don't think so either. plus i can't think of any benefits of doing it your way.
________________________
RickRick
posted on 3/12/08 at 08:32 AM Reply With Quote
i can it was easy! i thought as much i'll get it sorted before next thursday
adithorp
posted on 3/12/08 at 08:46 AM Reply With Quote
SVA doesn't require side lights to work with ignition off. Just the hazards that do. I can't see any advantage of the way your doing it though.
adrian
http://jpsc.org.uk/forum/
RickRick
posted on 3/12/08 at 01:18 PM Reply With Quote
i figured that the key would be removable in the park position which would have left the side lights on, as it does on my bike, but after a good hard tug, i realised it wasn't going to come out
posted on 3/12/08 at 07:29 PM Reply With Quote
adrian
What about when you park your car in a dark road? You are legally required to have your sidelights on in that situation - so, "sidelights on with the key out".
The clue is in the SVA name for those lights - 'position lamps'.
