dutchsuperseven
posted on 25/1/04 at 05:01 PM |
Digital dash panel
Does anyone know how to build a digital dashpanel? It's got to have a speedo!
A manual or internetlink would be useful to.
Greetingzz, Rob
Sex, drugs and Supersevens
PioneerX
posted on 26/1/04 at 11:35 AM |
dutchsuperseven,
I'm just finalising the design of a set, Tachno, Speed, Temp & fuel. I plan to release the electrical diagrams for everyone to use. However
struggleing with an appropate sender. My design uses a PIC mircocontroller perogrammed with the diff ratio, Tyre size & number of pulses per
revolution of the prop. But still testing cheap sender systems to make the whole unit as cheap to produce as possible.
I'm personally doing them all to fit inside a housing of a mini's gauge.
What do you think on the sender side. I thought about useing a magnet and high speed reed switch.
Regards
Simon
Fifer
posted on 26/1/04 at 12:03 PM |
Digital dash
It seems you are probably looking to build one. But take a look here.... http://www.intellitronix.com/
Under Street series or universal topics
I can supply all Nordskog products in UK / Europe and they are very good quality and very well priced.
Fifer
Northy
posted on 26/1/04 at 06:37 PM |
Fifer I can't find your email address anywhere. Can you email me?
Graham
dutchsuperseven
posted on 26/1/04 at 06:54 PM |
Hi Simon,
Im using a Ford Scorpio/granada gearbox equipped with a Hall-effect speed-sensor.
The sensor generates a 5V signal.
It normally drive's the original speedo.
Your Vx-gearbox shuold be equipped with a similar type of sensor.(when your using a carlton gearbox).
Greetingz, Rob
quote: Originally posted by PioneerX
dutchsuperseven,
Regards
Simon
posted on 5/2/04 at 12:34 PM |
Fifer,
how much can you do the 6 gauge universal panel for. Like Northy, can't find your e-mail address.
jmbillings
posted on 9/2/04 at 11:07 PM |
for a sender for our leccy speedo, we ended up using the sender for a Halfords bike computer, and a couple of small magnets bonded to the prop with
araldite. Remember to mount the sender next to the prop, not above it though, else the first time you hit a bump it'll break ![](/images//smilies/wink.gif)
PioneerX
posted on 10/2/04 at 02:10 PM |
jmbillings,
Halford bike sender, had not thought of that (provides the correct signal I need).
Why is it I always miss the obvious.
Thanks for bring this up.
Simon
jmbillings
posted on 10/2/04 at 02:16 PM |
Yep, I know what you mean- we got through two senders from Merlin@ nearly 30 quid each, and then realised a 7 quid halfords bike computer would do the
same and be more reliable- niceley waterproofed and so on!
JamJah
posted on 10/2/04 at 07:55 PM |
Is there anything in the SVA which says that you couldnt just a bike computer as a speedo? Not going to do it but just fancy seeing if the rules are
as silly as they apear sometimes. My bike clock goes to 99.99 so is realistically a cheap alternitive!
posted on 11/2/04 at 12:24 PM |
Lots of people use a bicycle speedo to pass SVA. Just have to make sure its illuminated
