plantman
posted on 26/12/08 at 07:41 PM |
will it pass or won't it pass?? help please
the master cylinder is just touching the bulk head
question is will it pass or won't it
what does everybody think?
Humbug
| posted on 26/12/08 at 07:50 PM |
Do you mean the reservoir is touching the bulkhead?
First thing to check is that it is not pushed away from the bulkhead, i.e. the reservoir isn't being "bent" on its mount.
If that's OK you could glue a small strip of rubber on the bulkhead to reduce the effect of any vibration.
Still not sure what Mr SVA would say
Mark G
| posted on 26/12/08 at 07:57 PM |
you could always fit a spacer between the cylinder and the bulkhead, You'd just need to lengthen your push rod by a few mm too.
plantman
| posted on 26/12/08 at 08:31 PM |
looks like a spacer could be easiest
unless someone got a better idea?
ashg
| posted on 26/12/08 at 08:39 PM |
if you have, had to question it, then in your mind you think that it's not ok. i would make a spacer for it and im sure the sva tester would
suggest the same.
i dont think it would fail but it would definatly get a mention.
it will be a lot easier to make a 2p spacer now rather than fail the sva still have to make a spacer and then pay for a retest.
[Edited on 26/12/08 by ashg]
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
marshall
| posted on 27/12/08 at 12:44 AM |
remove the reservoir and use a rubber hammer and hit a dent in the fire wall to allow it to have a small gap between them
it's up to you. hit it if it's only just touching the firewall to make a clerance. just a thought....
[Edited on 27/12/08 by marshall]
snapper
| posted on 27/12/08 at 05:38 AM |
I would go with relieving the bulkhead with a ball pean hammer myself
I eat to survive
I drink to forget
fesycresy
| posted on 27/12/08 at 10:06 AM |
My resevoir touched so I pulled it off and turned it around.
It then fitted perfectly !
Simon
| posted on 27/12/08 at 11:48 AM |
Mine touched so I cut a (bigger) hole in the bulkhead (well, it was full when I decided to do something about it, and removing it didn't figure
in my list of "fixes" )
Simon
