maskell01
| posted on 8/1/09 at 07:55 PM |
Harness SVA Compatable???
Is a 3 Point Harness like this one SVA Compatable?
prawnabie
| posted on 8/1/09 at 08:00 PM |
Will as long as its E marked. Beware that even if its FIA approved, it still needs to be E marked to pass.
HTH
Shaun
blakep82
| posted on 8/1/09 at 08:05 PM |
^ check the manual on that, as it says something along the lines of it has to have 'one of the following approval makrs', one of which is
the E mark
________________________
blakep82
| posted on 8/1/09 at 08:18 PM |
check all seat belts fitted either:
a) bear one of the following approval markings confirming compliance
-a designated appoval mark (E or e)
-a british standard marking for passive belt systems (BSAU183:1983)
-a british standard marking for a harness belt (BS3254:1960 or BS3254 part 1 1988)
-a specification marking which (in association with documentation where necessary) demonstrates that the requirements of a european standard
corresponding to any of the british standards for a seat belt for use by an adult as referred to in regualtion 47 of the road vehicles (C&U)
regulations or
b) have equivalent characterisitics to that of a belt approved for the same catagory of vehicle
check the characteristics include,
i) the webbing is of equivalent type of material and where it is likely to come into contact with the body of the wearer is at least 46mm (33mm for
harness belt shoulder straps) in width
ii) all componants are protected from corrosion
iii) the buckle, when under load and not under load, can be released by a single movement in one direction by either hand
iv)the locking mechanism is not less than 46mm in width
v)for static seat belts there is a manula adjusting device
-accesible to the wearer while seated
-easy to use
-capable of being tightened with one hand
vi) for a retracting belt
-blah blah blah.
there's a lot more to it that being E marked....
prawnabie
| posted on 8/1/09 at 08:27 PM |
Sorry should have gone into more detail!
I have put a car through an SVA with these harnesses on,which passed, but there are some sabelt harenesses that are FIA marked, and not E marked!
FIA probably exceeds most of those sepcs above, but is not tested to them - hence SVA failure (or so the examiner told me lol).
Shaun
[Edited on 8/1/09 by prawnabie]
blakep82
| posted on 8/1/09 at 08:34 PM |
true enough its a bit more cut and dry if they've got the e mark on them. but as you see from what i copied out the SVA manual, they don't
HAVE to have the E mark
but if they are e marked, its easier
[Edited on 8/1/09 by blakep82]
prawnabie
| posted on 8/1/09 at 08:35 PM |
Ah see what you mean now!
blakep82
| posted on 8/1/09 at 08:37 PM |
its certainly the angle i'm going for with mine....
Valtra
| posted on 10/1/09 at 06:37 PM |
Mine went through with Sabelt road harneses no problem , but I assume you are not using those exact belts unless you are building a 2 door saloon
version and need access to the rear seats and hence unbucle the rear mount ?
"If it looks like it works and it feels like it works, then it works"
