type 907
| posted on 2/2/04 at 12:46 AM |
Dash
Hi All
Has anyone passed SVA with a metal dash
i.e. no padding at all?
Assuming radii criteria are met, switches & gauges recessed etc.
Paul G
JAG
| posted on 2/2/04 at 12:15 PM |
I can't see why it would be a problem. It's what I plan to do - so I hope it's OK
Justin
MK9R
| posted on 2/2/04 at 02:08 PM |
Planning the same here too. Not expecting any problems
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
type 907
| posted on 4/2/04 at 12:21 AM |
No ones SVA'd an all metal dash then?
I only ask because I came across this bit of tit in the stock rack at work, guvnor said I could have it, an' it would be such a shame to cover
it up.
Could be the only bit of tit I get in the car!
Paul G
Too much is just enough
| posted on 4/2/04 at 08:50 AM |
Paul G
So Janet Jackson doesn't get to Sudbury too often, then?
garage19
| posted on 4/2/04 at 09:45 AM |
Unobtanium dash... you flash bugger!
DaveFJ
| posted on 4/2/04 at 12:45 PM |
what about your tit pedals?
I think I may just be able to afford some second hand plywood fro muy dash (if I ever get that far- If I ever get back in my gararge for that
matter:mad
Dave
type 907
| posted on 4/2/04 at 04:25 PM |
It's been renamed. Now called,
   ISOBTANIUM
The pedals don't count, any tit below
dash hight isn't worth looking at.
Paul G
JAG
| posted on 5/2/04 at 02:14 PM |
Be very careful with that tit'
Some grades work harden very easily and are then almost impossible to cut/form without specialist tools.
Perhaps I'm teaching my Granny to suck eggs? Good luck either way
Justin
jacko
| posted on 5/2/04 at 08:07 PM |
Paul
IS tit shiny.
I saw a car at a show with a aluminium dash the owner said it was crap in sunny wether
Jacko
type 907
| posted on 6/2/04 at 12:12 AM |
Hi
What you do with your granny Justin is your business.
Not shiny Jacko, sort of satin finnish.
The master plan is to temper colour it ,
purple round the clocks, out to blue, straw
then natural silver on the passenger side.
A bit of a job to explane so here's a pic of my bike, (one I made earlier) and you can use your imagination. Lettering is with a dremal by the
way.
Paul G
