Author: Subject: chassis ID - where/what from?
FASTdan
posted on 27/1/09 at 03:58 PM Reply With Quote
Quite a fundamental question, but where should my MK indy's chassis no. come from?
I bought the car from someone else part built. He scrapped the sierra donour but kept the ID plate from the engine bay stating chassis no. He also gave me an MK plate but that simply has MK and their contact phone number on it - below which is a space that looks like you might write a chassis no. in it.
I have searched a few posts and noticed some disagreements on what is required in this area - ie a riveted plate vs welded plate etc. I currently have neither!
Should I be using the sierra chassis no? or should I have one from MK? I have no problem in getting an ID plate stamped at work and I'll weld it on if required.
phoenix70
posted on 27/1/09 at 04:11 PM Reply With Quote
You need to get a chassis number from the DVLA (or make one up if you local DVLA office allows this - phone and ask) Then you need to get this number stamped permanently onto the chassis somewhere, normally the drivers side.
I tried to stamp it into the chassis but found it was just deforming the box section, so instead I stamped it on a piece of steel and welded it to the chassis.
Hope this helps
Scott
posted on 27/1/09 at 04:41 PM Reply With Quote
The path of least resistance is to write to your local DVLA office and request a VIN no. for your car. The stamp on a visible chasis rail in the engine bay - job done.
dinosaurjuice
posted on 27/1/09 at 04:43 PM Reply With Quote
some dvla offices request a seperate metal plate riveted to the chassis.
FASTdan
posted on 27/1/09 at 05:06 PM Reply With Quote
ok I've just bashed a letter out. how long does the process take?
caber
posted on 29/1/09 at 08:46 AM Reply With Quote
As with everythin to do with DvLA as long as they feel like plus another go to fix their cock-ups
Caber
DarrenW
posted on 29/1/09 at 09:08 AM Reply With Quote
I wrote to local office and proposed a number. Got a call within 2 days to say it was OK. They told me to stamp directly onto chassis or stamp a plate and weld it on.
The reason some people rivet a seperate plate in a more accessible position is so that its easy to get to and read should the need arise.
The second good reason why its good to write in is that if they call you back you can save their direct dial number. This can be handy.
When you say last owner scrapped the donor, do you know if it was officially scrapped (via the V5) or was it just physically scrapped (as in chassis disposed of but paperwork was kept)? If the latter this is good for re-registration later but ensure it is on SORN.
