deezee
posted on 5/2/09 at 12:18 PM |
Parts for Age related plate?
I'm struggling to find the Perfect Donor Sierra, a pre 1992 2.0L Pinto (with a suitable head for unleaded), with a type 9. This is mainly as I
want an age related plate, not a Q and I want to avoid a CAT test. Now if I get a CVH donor sierra and use everything off it (gearbox, diff,
uprights, loom, shafts, brakes, dash parts etc), less the engine, would it be enough for an age related plate.
If I could just get a sierra then find a engine separate, its going to make life easier.
[Edited on 5/2/09 by deezee]
posted on 5/2/09 at 12:23 PM |
Yes my friend, just put the engine number for your build on the donor V5 and bobs your uncle.
will121
posted on 5/2/09 at 12:36 PM |
if using a old pinto didnt think will need CAT emission test however i though you needed 8 points from using major items from doner to get an age
related plate?
posted on 5/2/09 at 12:46 PM |
The 'Built Up Vehicle Inspection Report' V627/1, list major components for a car as;
Chassis/Body Shell
Axles
Transmission
Steering Assembly
Engine
Suspension (front and back)
You only need to use 2 of the above from a donor vehicle to qualify for an age related plate and as the form is rather vague it is open to
interpretation.
You can even fit a bike engine and still easily qualify for an age related plate.
Phil
adithorp
posted on 5/2/09 at 01:08 PM |
You only need to be pre '95 to avoid cat test, not 92.
adrian
http://jpsc.org.uk/forum/
Ben_Copeland
posted on 5/2/09 at 05:49 PM |
why not fit a CVH engine and then change after SVA... that way you a definately going to get age related plate and no CAT needed.
After SVA and Registration you can do what you like !
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
Danozeman
posted on 5/2/09 at 05:55 PM |
Get a cvh donor one and then a pinto engine and have the pinto engine number put onto the donors V5 as said. Youl definatley get age related with
that.
My dvlla inspector said theyl only giv an age related plate if you have the V5 from the donor as proof.
Dan
