vinnievector
posted on 17/2/09 at 08:22 PM |
pinto age
Hi guys about two weeks ago i posted on here about a 2ltr pinto and how to asertain its age .
I was told to use the Burtons cat and also contact ford tec centre , i did both.
My eng number begins wt this has two ages attached Aug 1979 and april 1998 In the Burtons cat .
this was also the answer i had from Ford tec centre However i did fail to tell them that it was a ford pinto they did ask this Q in the reply to me .
As you can see i dont want the April 98 date for the eng as this will bring me into cat emissions and judging on the condition of the eng when i
bought its not 98 and not injected or unleaded so this must be much early than April 98
So some detective work now ,when i aquired the kit car it came with asorted bits nothing fitted and i was under the inpression that it was off a ford
sierra as it came with the diff brakes T9 box ext ext all from a Sierra so assumed that was the same . I now have my doubts for this reason if i go
for the 1979 date this is pre Sierra .
So i need to know when the stopped using the pinto ,when they stopped building the Sierra and when unleaded came in . this should pin down the date
for me .
Paul TigerB6
posted on 17/2/09 at 08:28 PM |
Pinto's are all nearly as old as the dinosaurs . Safe to say yours is a 1979 vintage then as the DOHC replaced the Pinto for the last
couple of years or so of Sierra production (which ended in 1993).
Looks like you have a Cortina block anyway.
jacko
posted on 17/2/09 at 08:33 PM |
Think cortina / capri had blue rocker covers sierra had black yours look like its original black in your photos i would say yours is 1975
lotusmadandy
Vinnie,,
the sierra went out of production in
1993 and so the last pinto was made i
am led to believe made in late 93.
Also there was not a pinto made with a cat.
are you certain the block is the original
one fitted to the car and not a replacement.1979 engines are fine if they are recon'd.My mate has a sweet 1980
1600 that has'nt been touched.
lotusmadandy
posted on 17/2/09 at 08:38 PM |
I think it is safe to say august 79
vinnie,can't be a 98 block.
meany
posted on 17/2/09 at 10:27 PM |
the 2.0 pinto was replaced circa 1989 by the 2.0 Dohc (twink)...i had an 89 dohc sierra ghia myself. you could ask on the following link.
http://forum.fordsierraclub.co.uk/index.php?sid=4e0362043b8111927b537c4671276731
vinnievector
posted on 17/2/09 at 10:57 PM |
Pinto age
Thanks guys this has confirm wot i thought so armed with this info i shall write off to Ford tec dept again and get them to confim this .
Just a bit of spec on the pinto i have ,this was purchased with the car but not fitted to the chassie and lay with the head off and water in one of
the bores the head was a leaded stadard 2ltr head and was later found to have a crack between bores ,this was later replaced with injection head with
a FR32 kent cam kit ,gas flowed and clead up .the block was found to be out of limits on one of the bores due to corrosion and scoring so i had the
block bored out to 2.1 set new pistons the rods where fine new shells and crank re-grind sorted out the block along with a new water pump and oil
pump i fitted a cozzy sump, new elec dizzy and coil from lucas boggs maifold and a set of R1 carbs .I fitted the engine summer of last year but due to
house moves only got around to starting up two mths ago so some tuning issues to sort out .
Paul TigerB6
posted on 18/2/09 at 08:50 AM |
Not sure there is any need to do this (unlike with Zetec's - which i did confirm with Ford Tech Centre). ALL Pinto's (before some smart
arse comments i know you can buy a new alloy block from Burton) are pre 1995 and so the SVA examiner shouldnt need proof of age for emissions testing.
Dont know anyone who has needed to prove a Pinto age anyway
