Scoobythedog
posted on 27/2/09 at 12:05 AM |
SVA Gearstick
Currently got an old red snooker ball sat on the top of the gearstick, will this pass SVA, or is there any rules that apply to having a diagram of the
gears on it ?
Scooby
omega0684
posted on 27/2/09 at 12:08 AM |
it should be ok, mine didn't have and indication of gears on it and the inspector didn't say anything about it
jabbahutt
posted on 27/2/09 at 09:19 AM |
same here no gear indications for SVA and no problems with the test.
wilkingj
posted on 27/2/09 at 09:27 AM |
Mine passed SVA with an Snoooker "8" ball on it. (my car is a Black V8, so looks good)
So did Snuggs, he even has a kiddies 8 ball (small one) on his oil dipstick.
It will meet all the radius and sharp edge requirements etc.
I hot melt guled mine on.
However, DONT put the glue in the hole in the ball. It goes cold and you cant fit it.
Gently heat the end of the metal gearstick with a small blowlamp, then rub the gluestick on the lever until you have enough glue on it. Pop on th ball
and press down. You can still heat the metal gearstick lower down below the ball if it goes a bit too cold before you have fully positioned the ball.
It just takes a good while to cool down!
This worked very well indeed.
Best Regards
Geoff
http://www.v8viento.co.uk
Mr Whippy
posted on 27/2/09 at 09:34 AM |
a good how too there, ta
Richard Quinn
posted on 27/2/09 at 11:47 AM |
... and being pedantic, that's a pool ball then
Marcus
posted on 27/2/09 at 12:40 PM |
As long as the ball is a round 1 you'll be fine. Mine was round with a flat for a badge on top....FAIL!!!!
Needless to say a nice round one was fitted for the retest!!
Marcus
Because kits are for girls!!
FASTdan
posted on 27/2/09 at 03:18 PM |
why was a flat a fail then?
Marcus
posted on 1/3/09 at 03:42 PM |
It was the radius from the ball to the flat...there was none, it was a sharp transition.
Marcus
FEZ1025
posted on 1/3/09 at 04:44 PM |
But again as a pedantic, if the top of the gear knob is less than 150mm above the seat base then it's exempt anyway.
Alan...
Marcus
posted on 1/3/09 at 06:30 PM |
My gear lever is about 150mm long and sits on top of the transmission tunnel. The top of this is about 110mm above the seat base, so 260
altogether....as I said FAIL
[Edited on 1/3/09 by Marcus]
Marcus
