Author: Subject: Reflectors
Pdlewis
posted on 11/3/09 at 09:16 AM Reply With Quote
Reflectors
Just a quickie
do reflectors need to be E marked? (For SVA)
Build Photo Album
Updated 05/02/2009
Mr Whippy
posted on 11/3/09 at 09:38 AM Reply With Quote
no, just needs to be a reflector though I think they'd object to tape being used and I’m sure it has to be 90 degs to the road
l0rd
posted on 11/3/09 at 09:50 AM Reply With Quote
I do believe though they need to be round? as triangular ones are for trailers.
adithorp
posted on 11/3/09 at 10:39 AM Reply With Quote
Must be red and retro-reflective (lots of little prisms). Don't have to be e-marked but if not should have similar properties (you might have to prove). Don't have to be round. Mine are/were oval and plenty have rectangular ones. Can't be triangular though.
adrian
http://jpsc.org.uk/forum/
FEZ1025
posted on 11/3/09 at 10:58 AM Reply With Quote
Also don't have to be 90 degrees to road, but although there is no actual specification I was once failed on a set that were about 45 degrees to road & deemed not reflective enough. There are also maximum measurements from the outside, I had another fail on them being 25mm over this amount.
Alan...
