Author: Subject: Boot lid and SVA
Vindi_andy
posted on 11/3/09 at 08:31 PM Reply With Quote
Boot lid and SVA
Guys can you answer this odd one for me.
If I run out of time doing all the stuff thats really required for SVA is it possible to fix the boot lid so that it doesnt open.
According to my mechanic mate it has to be able to open for the MOT but does this also apply to SVA
In additon does the number plate light have to be fitted?
mistergrumpy
posted on 11/3/09 at 08:33 PM Reply With Quote
Yes you'll have to remove the boot cover for SVA so that the inspector can see what's below it i.e. the wiring etc.
As for the number plate light then I'd have thought yes. You're not presenting a roadworthy car without it.
daniel mason
posted on 11/3/09 at 08:34 PM Reply With Quote
would not think so. most mnr's have a solid carbon sheet over rear end which is screwed down. that cant be removed.
mistergrumpy
posted on 11/3/09 at 08:35 PM Reply With Quote
It can be removed when it has to be unscrewed. That's what the inspector asked me to do, luckily I had a removable panel in it though that he hadn't seen.
speedyxjs
posted on 11/3/09 at 08:55 PM Reply With Quote
I think i remember someone SVAing without a boot lid. Just left it open
jacko
posted on 11/3/09 at 09:09 PM Reply With Quote
I had a lid but when removed there is a box / boot under it
my car passed first time no problem
that was 5 years ago
snapper
posted on 11/3/09 at 09:17 PM Reply With Quote
Beware the Dome of Death
If you can get the dome to the sharp bits the car will fail.
One Guy (Scottie) used a sheet of perspecs, SVA could see but not touch
I eat to survive
I drink to forget
Slater
posted on 11/3/09 at 09:19 PM Reply With Quote
I had a central screwed down section on my boot lid, I was asked to remove it so he could see inside to check seat belt top mounts and all wiring/piping.
SVA was last Friday.
joemotion
posted on 11/3/09 at 09:22 PM Reply With Quote
i had mine screwed down and said that he would want to look in it later on in the test however never did!
Vindi_andy
posted on 11/3/09 at 09:35 PM Reply With Quote
was thinking of bolting it through the mounting flanges but not lining out the boot area so he would be able to see everything from underneath
smart51
posted on 11/3/09 at 10:25 PM Reply With Quote
Mine opened but had a boot tray underneath. He didn't ask me to remove. He told me that it could be covered in razor blades and would have passed but the "sharp" edge on my reflectors had to fail. He seemed really apologetic. I was under the impression they couldn't ask you to dismantle the car if it couldn't be done with the tools that come with the car.
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 11/3/09 at 11:38 PM Reply With Quote
mine had the standard MK boot lid in the back, was never asked to take it off (though it is removable) he just looked from underneath the car....
Mark G
posted on 12/3/09 at 12:25 AM Reply With Quote
When applying for my sva I seem to remember reading that you have to take tools with you and be prepared to remove any panels required (within reason).
