chris_smith
posted on 18/3/09 at 08:54 PM |
pre sva pics for your perusal/comment/abuse
SVA this friday 8am
ok so im nearly finished been set back a day or so this week with one or two problems which are now resolved,
still have the rear arches and lights to fit so here are the pics of the front end
and having spoken to sva man at chadderton he suggested it was ok to come without the final colour painted so that will be finished after i get it
passed
i know about the top ball joint that needs covering
are there any other things people can see
regards
chris
[Edited on 18/3/09 by chris_smith]
Howlor
posted on 18/3/09 at 08:59 PM |
Quite a few sharp edges on the suspension etc, exhaust clamps etc. Positive terminal on the battery needs a cover. Do the mudguards cover the wheel
when looked at from above?
jacko
posted on 18/3/09 at 09:00 PM |
Front indicators don't look far enough out 400mm from out side of the car [ not just the front ]
exhaust clamps are no good before the can
The side mirror's look a bit low to see over the rear mud guards but i may be wrong
[Edited on 18/3/09 by jacko]
Paul TigerB6
posted on 18/3/09 at 09:03 PM |
Not sure they will like the covering on the steering arms. You can buy proper covers to go over the nuts to the track rod end that look really good
(and look better than a bare nut so dont need to fall off). Cover the lock nuts on the top ball joint - wishbone.
Mirrors look a bit low - not sure you will pass with them by the time the rear wings are fitted.
When is your SVA?? i'll be at Chadderton twice in the next month myself!!
adithorp
posted on 18/3/09 at 09:04 PM |
Headlights...edges too sharp?
Exhaust clamps... edges?
Indicators...distance from wides part? (400mm max)
Front wing mounting bolts...edges?
Difficult to tell in the pictures but those were my first impressions...and first impressions really count for a lot with the testers; The neater and
tidier the better even if it isn't shinney.
adrian
http://jpsc.org.uk/forum/
chris_smith
posted on 18/3/09 at 09:07 PM |
battery terminal cover is awaiting fitment,
exhaust clamp is to be changed tomorrow
mudgaurd covers wheel from above
indicators are within limits
headlight rims havent been fitted yet due to mot guy round corner going to set headlight beam for me
which sharp edges can you point them out please, sometimes you cant see the wood for the trees
thanks
Howlor
posted on 18/3/09 at 09:22 PM |
Cockpit sides radius? Mudguard mounts radii?
mad-butcher
As said Indicators max 400mm in from widest part of car (in the case of the indy the rear arches). to cover the nut on tre you need an electrical
gland nut cover also sold by tiffosi. exhaust clamp use one off a motor bike.
tony
snapper
posted on 18/3/09 at 09:36 PM |
Top balljoint to wishbone nut
I eat to survive
I drink to forget
Dangle_kt
posted on 18/3/09 at 10:05 PM |
First of all mate, well done. I think you have done really well! I'll edit the message once I;ve looked at the pictures properly
myke pocock
posted on 18/3/09 at 10:32 PM |
Took my x flow engined car out the other day for a shakedown run pre SVA and found that the underbonnet temp with an unlagged exhaust manifold was
very high, so high in fact that it made the side of the battery (mounted on the top of the footwell behind the exhaust manifold) very hot and
flexible. NOT GOOD. Currently lagging the manifold. You may need to look at that but not an SVA prob if it doesnt get too hot for the test. For the
track rod ends I bought some large cable sleeves and fitted them but the tester advised that if he can feel the lock nut through them he would fail
it. Wrapped them with foam and fitted even larger ones over the top.
austin man
posted on 18/3/09 at 11:09 PM |
cable glands are good to use
myke pocock
posted on 19/3/09 at 12:09 AM |
I also think the rear edge of the scuttle may need covering and the gearstick gaitor surround may be to sharp. Similar to mine, I just rounded it over
and polished it off. Dont know if they will like the crankcase vent without its PCV valve and a tube. Good luck for the test. Mines next week. Let us
know how you get on.
DavidM
posted on 19/3/09 at 12:42 AM |
Hi Chris,
Well done for getting the car to this stage.
I'd agree with the comments regarding the track rod end covers.
If you haven't already done so, I'd check the angles of visibility of the front indicators.
If you rotate the exhaust clamps towards the body about 45 degrees you should be able to get the contactable bits to be non contactable. Nice front
clamp by the way.
You may need some edge trim on the flat bits of your wing stays.
Good luck with the test.
Proportion is Everything
welderman
posted on 19/3/09 at 08:22 AM |
Looking good there Chris, good luck with the test tomorrow
Joe
Thank's, Joe
I don't stalk people
Slater
posted on 19/3/09 at 09:56 AM |
Does the rear edge of your cycle wings come down lower than the centre of the wheel. If not just fit a temporary plastic mudflap.
Marcus
posted on 19/3/09 at 12:36 PM |
I don't think the rear edge matters, as long as the front covers the rim when viewed from above AND the wing itself is 120° coverage.
Marcus
Because kits are for girls!!
MautoK
posted on 19/3/09 at 04:36 PM |
Good luck tomorrow.
Remember to take edging strip and other remedial bits with you!
