Author: Subject: tacho SVA
belgian2b
posted on 19/3/09 at 07:08 PM Reply With Quote
tacho SVA
Hello,
does my tacho need to be operationnal for SVA ?
( i can connect my laptop to my ECU to show RPM at the tester )
Gerardo
tomgregory2000
posted on 19/3/09 at 07:10 PM Reply With Quote
NO you dont need one the only instrument you need is the speedo
speedyxjs
posted on 19/3/09 at 07:13 PM Reply With Quote
Yep, just a speedo
belgian2b
posted on 19/3/09 at 07:18 PM Reply With Quote
thank you !!!
smart51
posted on 19/3/09 at 08:21 PM Reply With Quote
If you don't have a tacho, how do you do the emissions and noise tests?
flak monkey
posted on 19/3/09 at 08:28 PM Reply With Quote
The sva man will have a tacho there which will either work form the coil or off a HT lead.
At my noise test he didnt even check the rpm. Told me to rev it up and then said it was ok.
Emissions are done at tickover on most engines anyway, unless you need a cat test.
Sera
http://www.motosera.com
