Author: Subject: SVA dash regs
chris-p-duck
Contributor
Posts 256
Registered 16/4/07
Location West Mids
Member Is Offline
Photo Archive Go!
Building: a sense of satisfaction now things seem to work ok
posted on 24/3/09 at 06:53 PM Reply With Quote
SVA dash regs
Hi all,
A quick bit of advice please folks -
I an planning on using a vapour digi dash but my current dash panel has some cut outs in it already for a set of analogue dials. So I was planning on using a nice piece of 1mm ali to cover it (vinyl is not an option as there is going to be basically no soft trim at all in the car). So my question is - would a 1mm raised section of ali cause a 'sharp edge' in the eyes of the SVA/IVA tester or do I need to somehow 'hide' the edges??
Thanks in advance
Chris
omega0684
posted on 24/3/09 at 06:55 PM Reply With Quote
cover the edge in a bead of silicone and then just peel it off afterwards, but i don't think a 1mm sheet would cause a problem
blakep82
posted on 24/3/09 at 06:58 PM Reply With Quote
just run around the edge with a fine file to sort of blunt it a little
________________________
Paul TigerB6
posted on 24/3/09 at 07:01 PM Reply With Quote
Or use some small U-trim - you know the stuff..... always seems to fall off after SVA!!
adithorp
posted on 24/3/09 at 07:30 PM Reply With Quote
Just has to be blunted. Run a file over the edge.
http://jpsc.org.uk/forum/
chris-p-duck
Contributor
Posts 256
Registered 16/4/07
Location West Mids
Member Is Offline
Photo Archive Go!
posted on 24/3/09 at 07:51 PM Reply With Quote
Thanks guys - I can get on with it now with a bit more piece of mind!
