Author: Subject: air filter hole in bonnet
cjtheman
posted on 25/3/09 at 09:37 PM Reply With Quote
hi all
what will i need to do to make it sva proof will have a filter out through top of bonnet
any tips on what you all done to sort it
cheers
colin
wanted
sunny weather
sva pass 12/6/09
taxed 16/6/09
omega0684
posted on 25/3/09 at 09:45 PM Reply With Quote
just put some nice trim around the edge of the hole to make it look nice.
cjtheman
posted on 25/3/09 at 09:50 PM Reply With Quote
will the chrome filter be a problem its self
cheers
colin
wanted
sunny weather
sva pass 12/6/09
taxed 16/6/09
wicket
posted on 25/3/09 at 10:13 PM Reply With Quote
RamAir foam filter on wire frame, hole trimmed. Not questioned at SVA
myke pocock
posted on 25/3/09 at 10:19 PM Reply With Quote
Just been SVA'd today. I edged the hole with rubber edging and applied self narrow adhesive draught excluder to the top and bottom edge of the filter. (try B & Q or similar for this. Available in brown and white and sometimes called E foam as it is E shaped) Passed no probs. The tester did ask if the edge was less than 2.5mm below the rubber. The rubber will certainly fall off some time though.
omega0684
posted on 25/3/09 at 10:27 PM Reply With Quote
do you have a picture of the filter
James
posted on 26/3/09 at 12:04 AM Reply With Quote
I think that's who made my one too.
Bought new from Rally Design for about £25.
Sure a cheaper one could be found somewhere.
James
