chris_smith
| posted on 25/4/09 at 06:29 PM |
re-test on monday- but im stuck!!!
need your guys to give me some ideas on what to do with the contactable edge on my Air filter picture below, tester failed it on not being correct
radius, iv spent the last 2 hours wondering around B&Q trying to find a suitable rubber or foam of some description to place on the edge but to no
avail,
so its out to you guys to come up with a solution
locostbuilders has never let me down and im sure you wont in my hour of need!!
Chris
Mark G
| posted on 25/4/09 at 06:33 PM |
Could you make a mesh dome to fit over the filter so that they can't contact the filter with their radius tool.
UncleFista
Take it off ?
It could then "fall on" after SVA ?!?!?
Tony Bond / UncleFista
Guinness
Rivet to bonnet.
Done.
Mike
Wadders
Why not just cover the whole thing up for sva, something like a stainless steel dog bowl stuck over the top with double sided sticky tape would do the
trick.
Al.
Crikey you lot were quick! Great minds and all that Mike
[Edited on 25/4/09 by Wadders]
Richard Quinn
| posted on 25/4/09 at 06:34 PM |
Is there an aquatics place near you that's open on a Sunday. Most do various grades of foam for pond filters. Fit a strip of that around the
whole filter and tell the tester that it is K&N pre-filter foam (which is available for off-road racing etc). May be worth a shot if you cant get
anything else
mistergrumpy
| posted on 25/4/09 at 06:35 PM |
Is it just the top edge? Can you not make a large kind of O ring out of some rubber and stick it around the edge?
AdrianH
What is the carb? I could lend you the Pipercross for a pieberg!
I noticed it is a crossflow.
[Edited on 25-4-09 by AdrianH]
Why do I have to make the tools to finish the job? More time then money.
RichardK
| posted on 25/4/09 at 06:38 PM |
My vote goes for taking the filter off and putting something like a dog bowl or similar glued from the inside.
Rich
Gallery updated 11/01/2011
| posted on 25/4/09 at 07:47 PM |
can't tell from very small photo but does the carb stick out above bonnet?
if not, get down to pouundland where they sell fine anit-spatter mesh for frying pans.
PU that on.
myke pocock
| posted on 25/4/09 at 08:15 PM |
I fitted e-foam to the edges of mine. Its used as a self adhesive draft excluder for windows and doors. If you cant get that, do you have any foam or
rubber sheet that can be cut into a narrow strip and stuck on using double sided tape? (get that from a craft supplier or Staples or similar)
pewe
| posted on 25/4/09 at 09:09 PM |
I used black multi-core electrical cable outer slit along its length then taker some off one edge to give a 3/4 round beading. Stuck it on with
Extreme adhesive from B&Q - expensive but sticks like whats it to a blanket (Evos -stik will do the same). If you nick the inner edges it should
curve to quite small radius.
BOL.
Pewe
Humbug
| posted on 25/4/09 at 09:24 PM |
...or smallish bore hose split and glued on
| posted on 26/4/09 at 06:37 AM |
I would take up the offer of the Pipercross filter , no edges exposed?
Valtra
| posted on 26/4/09 at 02:14 PM |
tuperware lid out of the kitchen cabinet ?
"If it looks like it works and it feels like it works, then it works"
