mad-butcher
posted on 5/5/09 at 07:29 PM |
IVA Rules on exhausts
I know there was some question about exhaust systems and the IVA needing to be completely enclosed, does anyone know what the final outcome was, fully
enclosed or as SVA
tony
blakep82
posted on 5/5/09 at 07:45 PM |
seems the IVA is now a free download. at least i managed to get it free, proper pdf, not a paper manula someone scanned on. i forget where i found it
though
google 'iva manual' and you should find it easy enough
________________________
blakep82
posted on 5/5/09 at 07:52 PM |
here in fact
http://www.mevltd.co.uk/downloads.html
eznfrank
posted on 5/5/09 at 08:09 PM |
Hmm, so a side exit pipe might stick out too far? - Balls!!
blakep82
posted on 5/5/09 at 09:03 PM |
can you turn the can to point down for IVA then turn it back out for side exit?
loggyboy
posted on 5/5/09 at 11:17 PM |
IF they intended it to mean 50mm insude the bodyline, could it be argued that they have worded this wrong?
In the case of side mounted exhausts the tailpipe must terminate no more than 50mm from the extreme outer edge of the vehicle
I would read that as, it can come out no more than 50mm from the widest point of the car. (Check page 255 for the sample diagram of 'extreme
outer edge'
Mistral Motorsport
eznfrank
posted on 6/5/09 at 02:15 PM |
Oh I've read it totally wrong. As it says "no more than" 50mm it must mean outside that area whereas I thought it meant it had to
be at least 50mm in from a line between front and rear wheels.
