jpindy3
posted on 20/5/09 at 03:43 PM |
i didnt pass iva
got up to micham ok loads of time to spare,the car was fine,apart from the carbs poping off the rubbers,and i think the timing is very slightly
out.
the inspetor was a very nice bloke,highly recomend micham as a place to get tested,
i got a list of 7 things to sort out all miner the bigest thing is to move the fuel pump,
booked a retest for to weeks time.
jamie
cd.thomson
posted on 20/5/09 at 03:44 PM |
where is your fuel pump jamie?
Craig
jpindy3
posted on 20/5/09 at 03:50 PM |
i just got to put it on the other side of a rail,coz if someone hits me up the arse the pump wont brake the tank
stevegough
posted on 20/5/09 at 03:53 PM |
Sorry to hear you failed, BUT -look on the bright side.
7 points of failure - you now have a concise list to work through.
Bottom line is - all points are minor - you are going to pass on the retest, no problem.
go for it !!!
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
blakep82
posted on 20/5/09 at 03:54 PM |
ooh, are you the first IVA'er off here?
________________________
richardh
well done anyway
Time for a change!
blakep82
posted on 20/5/09 at 04:03 PM |
if you are the first IVAer off of here, i think to come away with only 7 fail points after the problems you had last week is a great effort mate
jacko
posted on 20/5/09 at 04:18 PM |
Well done looks like you been the first with the IVA test you will have to put a list up of what others need to pass the test
IE was the side panels ok / did you need to panel under the dash and i have been told that if the brake calipers stick out the wheel rim [ inside ]
it will fail
This is only what some one has told me so may not be true
jpindy3
posted on 20/5/09 at 04:19 PM |
the thing is is that if i had the iva manual a few weeks ago i would have passed,
alex emailed me a copy 2 the other night i had a little look,but i thort if i find somthing that i carnt sort out il be climbing the walls,
so i went today thinking that it might not pass,oh well better luck next time
jpindy3
posted on 20/5/09 at 04:27 PM |
it will fail
i will make a list,the side repeters have to be mounted on the front wings, panal under the dash is not needed,you need to list the waight and make of
the car on the chisis number plate,a sticker showing what brake fluid it takes,
thats some of the changes made,i will do a list
omega0684
posted on 20/5/09 at 04:31 PM |
just u2u'd you mate,
sorry to hear that you didn't pass but good to hear that you only have a minors list
you'll be able to sort i over the weekend i guess, a couple of weeks gives you time to even plan your after IVA mods,
p.s no worries about the manual buddy, thats what we're here for
snapper
posted on 20/5/09 at 04:59 PM |
Sounds a promising start to the IVA for Locostbuilders.
Lets get a list going of who passed with what car and what points were fails etc.
We will soon build up a list of contentious points to look out for
Well done on a few fail points, sounds like no real issues either.
I eat to survive
I drink to forget
scotlad
posted on 20/5/09 at 05:06 PM |
7 fail points not bad at all- you're almost there! Well done you
Wonderous is our great blue ship that sails around the mighty sun, and joy to everyone that rides along!
blakep82
posted on 20/5/09 at 07:25 PM |
well, thats kind of even better! (for the rest of us at least ) that you've essentially followed SVA and got a better result than many first
time SVAers who had the manual
Daddylonglegs
posted on 20/5/09 at 07:29 PM |
Nice one chap!
Won't be long now then? All we need is a good summer!
A list would be great so all of us who have yet to have the pleasure of the IVA can stand a better chance.
