Author: Subject: Another SVA FAIL!!!!
j30fos
posted on 5/3/04 at 01:37 PM Reply With Quote
Had my retest this morning, failed again
Failed on non self centering.
drove my car last week to sort out emissions, drove to the test centre this morning, all fine. Booked in, told to drive to the SVA lane, got back in the car and no power, everything was dead. Mega pissed, so I bypassed the immobilizer and all worked fine, so this failed as well, but eay to repair.
To all you R1 guys out there PASSED THE EMISSIONS just though LAMBDA=1.02 with just the CAT on. So an air bleed system isn't really need on these motor's.
Things are looking good for Stafford, just got to sort out how to do the self centering, and then get it registered.
oh and this time gave the car a bit more death, loads of fun, very very quick.
Good luck chris with your retest next friday ( fingers crossed for ya ).
ned
posted on 5/3/04 at 01:39 PM Reply With Quote
self centring, increase the castor or toe out...
Ned.
beware, I've got yellow skin
Mk-Ninja
posted on 5/3/04 at 01:43 PM Reply With Quote
Hard luck that.
Loads of toe out aparently for self centreing, dont drive it too far like that though or youll scrub the tyres. Pity you couldnt have adjusted it at the test centre.
Easy fix though
I'm sure I've got one, just don't know where I've put it
Kitlooney1000
posted on 5/3/04 at 02:41 PM Reply With Quote
unlucky j30fos. better luck next time
Terrapin_racing
posted on 5/3/04 at 03:18 PM Reply With Quote
any use?
Terrapin_racing
posted on 5/3/04 at 03:19 PM Reply With Quote
better if I attach it!
posted on 5/3/04 at 04:01 PM Reply With Quote
John,
3rd time lucky mate. Won't be long.
j30fos
posted on 5/3/04 at 05:00 PM Reply With Quote
Just got back in from ATS, the steering was way out.
THE CAR NOW SELF CENTER'S , took me dad out in it, he's still shaking not sure if thats from the cold or the performance.
Looks like its just the immobilizer to sort out and thats it. Going to re-book the test on Monday
j30fos
posted on 6/3/04 at 10:24 AM Reply With Quote
All jobs sorted now, going to book a retest for tuesday wednesday. Keep you all posted
posted on 6/3/04 at 02:51 PM Reply With Quote
Increase the toe-in (try 3/16" to 5/16" -- under no circumstances should it have static toe-out !, also try lower tyre presures to get the self aligning action of the radial tyres to work.
If you can increase the caster angle top steering ball joint should be behind the lower ball joint --- on MK wish bones you can do this by flipping the to wishbone over.
Mix
posted on 6/3/04 at 06:36 PM Reply With Quote
Arrghh!!
Toe in / toe out
Mick
I'm off to buy a book. Any suggestions ??
Keep them clean.
[Edited on 6/3/04 by Mix]
James
posted on 6/3/04 at 06:57 PM Reply With Quote
How will flipping them over help? They are handed. If you have them the right way round then flipping them will reduce the castor.
Also, flipping them so they're upside down will mean the BJ can't operate properly as the threaded tube points 'up' relative to the droop of the wishbone.
Two of Bob's photos show this:
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=indy0101.jpg
and
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=indy015.jpg
James
OX
posted on 6/3/04 at 08:00 PM Reply With Quote
good luck with the retest dude ,hopefully see you next sunday woohoo
greggors84
posted on 6/3/04 at 08:19 PM Reply With Quote
Toe in, is when the front of the wheels are pointing inwards view from above and toe out is the opposite. Best way to work it out is to look down at your feet. Put your toes in, thats how your wheels look when you have toe in! Simple!
Chris
The Magnificent 7!
posted on 6/3/04 at 08:30 PM Reply With Quote
Toe in
I thought this was toe in:
or is that wrong? Don't know who it is but it works...
posted on 6/3/04 at 08:32 PM Reply With Quote
Or if you prefer...
Madonna's "toe in":
Careful!!!
