Author: Subject: Light cluster
Lightning
posted on 5/3/04 at 07:39 PM Reply With Quote
Light cluster
I have the block type of light cluster, a la Cateringvan,
Do they have to be mounted vertical (the reflector is intergral).
On cateringvans they look higher and better to boot, but in my abridged version of the good book it just says they should be rearward facing...no sh*t.
Dont want to drill unnecessary holes so help is required.
posted on 5/3/04 at 08:05 PM Reply With Quote
Mine are just mounted on the rear wing (facing rearwards) and they passed. I think it only applies to the rear hazard.
yours, Pete.
Deckman001
posted on 5/3/04 at 08:13 PM Reply With Quote
I thought they had to be facing horizontally, ie facing the cars behind you and not shining up towards the sky in any way ??
Jason
I think caterham use a wedge shaped spacer don't they
[Edited on 5/3/04 by Deckman001]
madforfishing
posted on 5/3/04 at 08:23 PM Reply With Quote
Pretty sure Deckman is right. I remember Mark Evans built that Westfield on TV and he had to add the spacer to make the cluster parallel with the ground.
Lightning
posted on 5/3/04 at 09:33 PM Reply With Quote
I've got the wedge shaped block. The verticallity depends on how far around the curve of the rear wheel arch you set them.
