a4gom
| posted on 22/6/09 at 03:12 PM |
ground clearance
Not really an IVA question unless its covered in the test but does anyone know if there a legal minimum?
Just a thought with all these humps and bumps appearing on the street, the DOT apparently recommend a max height of 70mm now for these but where do
they get that figure?
Perfect planning prevents pi$$ poor performance!
l0rd
| posted on 22/6/09 at 03:14 PM |
I thought that 7s are height adjustable?
Can't you just lift it for IVA?
blakep82
| posted on 22/6/09 at 03:20 PM |
theres no minimum, but speed bumps are generally at a max height of 10cm. my car is only about 9cm for the chassis, the sump hangs lower...
________________________
a4gom
| posted on 22/6/09 at 03:22 PM |
I don't know if IVA covers it and I'm on the road anyway now so it doesn't really matter, I was just pondering on how they can get
away installing humps in the road if there is no legal minimum ground clearance for vehicles?
I found this here which says there is no legal
requirement
blakep82
| posted on 22/6/09 at 03:27 PM |
and they mean you have to keep accelerating, meaning you use more fuel = more pollution. terrible idea...
| posted on 22/6/09 at 06:56 PM |
You don't want to be too low for the IVA - when my car was SVA'd it had to go up ramps onto a hoist, and then the wheels had to drop into
the brake tester/speedo checker thing.
If you're too close to the ground you'll struggle.
Most people here reckon that a minimum of 100mm is a good idea.
