Author: Subject: Good Day - Bad Day
LBMEFM
posted on 6/7/09 at 06:02 PM Reply With Quote
Good Day - Bad Day
Good Day- Prior to this mornings SVA retest I took out my MK Indy for the first time to check the speedo before putting it on the trailer. Wow just could not stop smiling, how brilliant's that. Got to the SVA centre at Gillingham, great guy went through my failure list all OK now including wiring, fuel system, noise level and various sharp items etc.
So just the emissions to test and you have got yourself a pass. Bad day, the readings are way out. He showed me the reading, means little to me, on the first test it read L-0.705, Co evo1-9.04, Co evo2- 8.9, 02 evo1-0.06 & HC 2140 Second test the readings at higher revs were L-0.704, Co evo1-10.44, Co evo2- 8.3, 02 evo1-0.04 & HC 893. He said he requires the readings to be Co -0.3% or less, HC -200ppm, Lambda -0.97 to 1.03 all at 2500 - 3000 rpm. And the CO 0.5% at idle. I showed these figures to a mate who owns his own bike shop and race team and his first reaction was it's mission impossible. Any ideas how I can get over this please it's a 95' RRS 843cc Blade engine on carbs.
prawnabie
posted on 6/7/09 at 06:16 PM Reply With Quote
Did your mate realise it only has to be that low for the actual test?
Id either lean it right out for the test, or use a power commander with an sva map on it
Shaun
StevieB
posted on 6/7/09 at 06:19 PM Reply With Quote
I had a similar problem on my R1 (carbs).
Firts time out it was just the lambda that was out (just).
After a good cleaning of the carbs and fiting a borrowed airbox rather than my foam filter, the lambda was OK but the CO and HC's were WAAAAAAAAAY out.
Took the airbox off and dialled down the air/fuel screws on each carb quarter turn at a time until the numbers stabalized in the right place.
Got the tick in the box and turned the carbs back to the right place before I even put it on the trailer to leave the VOSA centre....
[Edited on 6/7/09 by StevieB]
belgian2b
posted on 6/7/09 at 06:21 PM Reply With Quote
No power commander cause it's carburetor engine.
what is the exact engine date ?
can't you pass on the old values ?
[Edited on 6/7/09 by belgian2b]
mad-butcher
posted on 6/7/09 at 06:32 PM Reply With Quote
What all this lamba etc thought 95 was just std emmissions,
tony
robinj66
posted on 6/7/09 at 06:34 PM Reply With Quote
can you take it into a bike workshop and get them to tweak it using their equipment.
I would suggest DHR at Whitfield
posted on 6/7/09 at 06:46 PM Reply With Quote
Firstly, do you have a letter from Honda confirming the exact date of your engine? If it's a pre 1st August 1995 engine, the emissions limits are considerably lower;
3.5% CO
1200 ppm HC
Phil
Ben_Copeland
posted on 7/7/09 at 08:58 AM Reply With Quote
Did you try loosening off the seals between the carbs and the manifold?
Too introduce some air to lean it off?
Think Roger suggested that one before?
Ben
Locost Map on Google Maps
Enter Your Details Here
Gav
posted on 7/7/09 at 03:33 PM Reply With Quote
3.5% CO
1200 ppm HC
Phil
My blade is pre 95, all i had to do was show the nice VOSA chap the haynes manual with the engine code range that match mine for the year.
posted on 7/7/09 at 05:06 PM Reply With Quote
Showing the Haynes manual to the inspector is OK (at some SVA centres) provided the engine year is pre 95. The problem arises when you have a '95 engine and the inspector will want some proof that it's pre 1st August.
Phil
