chris-p-duck
| posted on 8/7/09 at 07:42 PM |
Brake / Fuel line securing
Hi all,
I am in the process of routing and securing the fuel and brake lines and an looking at how to fix them securely. I am sure that I have seen somewhere
on here that there is a recommended gap between the fixings to keep the IVA man happy but I cant seem to find it anywhere.
I have read the manual and it only talks about adequate fixings which is kinda vague and open for interpretation.
Any advice gratefully received.........
Chris
eznfrank
| posted on 8/7/09 at 07:46 PM |
The manual doesn't seem to make much mention of it for brake lines other than to say secure. The standard on here seems to be 150-200mm. I did
mine at 150mm to make sure............(he says running away to check manual).
From memory fuel lines are at 300mm but obviously need to not rub etc.
[Edited on 8/7/09 by eznfrank]
blakep82
| posted on 8/7/09 at 07:51 PM |
30cm is the recommended max gap from SVA. stick with that and i don't think you can go far wrong. but you're right, i've found the
IVA really vague on fuel lines. it doesn't even say anything about the markings fuel hose needs or anything,
________________________
300mm --- ie 1 foot
For brake lines tin top style pop in plastic fittings are very good and look more pro than other types
These arel availble from usual sources including local motor factors, ebay
ebay item 270311950474
double type ebay item 250444087195
chris-p-duck
| posted on 8/7/09 at 07:56 PM |
The photo of the double clip on ebay is possibly the worst photo I have ever seen on ebay!
Thanks for the recommendation though!
blakep82
| posted on 8/7/09 at 08:27 PM |
it really annoys me the manual doesn't say whats acceptable and whats not. i don't really want to drill more holes in my chassis. its
already full of them
Macbeast
| posted on 8/7/09 at 09:08 PM |
" Add lightness" - Colin Chapman
[Edited on 8/7/09 by Macbeast]
omega0684
| posted on 8/7/09 at 10:09 PM |
no more than 300mm apart! must be secured to the chassis (p-clips etc) must not rub or chaf anything obviously.
robertst
| posted on 8/7/09 at 11:50 PM |
i thought it was 100mm, not 300... i'm saying this because it's what it says in the haynes manual (Gibbs)
i did it every 100...
Tom
mad4x4
| posted on 9/7/09 at 06:30 AM |
Watch where they come past the Diff, Uses some of that plastic split tubing top protect them.
Scot's do it better in Kilts.
