Author: Subject: Clutch Slip (R1 2003)
spdpug98
posted on 12/7/09 at 10:24 AM Reply With Quote
Just been out for my first proper run in the car, it was a bit damp so was taking it a bit easy!
But when ever I give the car some beans the car rev's its nuts off, it starts to pick up but then the rev's just shoot up.
Is it possible that the clucth needs adjusting or does it sound terminal
My Blog: http://spdpug98.wordpress.com/
nitram38
posted on 12/7/09 at 10:28 AM Reply With Quote
If you have some adjustment, try backing it off........it could be that you are not allowing the clutch lever to return fully after you have lifted your foot off.
Major Stare
posted on 12/7/09 at 11:41 AM Reply With Quote
Find my post on this section.
Ive adjusted mine this morning as i had similar problem last week.
Jon "FISH"
nitram38
posted on 12/7/09 at 11:45 AM Reply With Quote
If backing it off does not work, before you bin the clutch, try the spring mod.
I think on the 03 it you double up on the front spring plate?
I know on my 05 it is barnett springs.
jambo
posted on 12/7/09 at 12:25 PM Reply With Quote
i had thuis first couple of runs.turned out just to be the clutch pedal not returning fully about 1 in 10 times.
spdpug98
posted on 12/7/09 at 12:49 PM Reply With Quote
Thanks for all the replies, I have adjusted the clutch end and moved my clucth stop by the pedal box
Just been out and that's what it is supposed to do!!!!!!!
