Author: Subject: SVA mirror size
james h
posted on 17/7/09 at 04:04 PM Reply With Quote
SVA mirror size
Hello all,
I am almost ready for my SVA retest, just a couple more things to do.
One thing I need to do is attach the wing mirrors. I have some fancy aerodynamic things at the moment, and was wondering if there was a minimum size? 70mm by 40mm rings a bell.
Mine are about 115mm wide by 50mm high.
James
nitram38
posted on 17/7/09 at 05:26 PM Reply With Quote
You are a bit late for sva
james h
posted on 17/7/09 at 05:34 PM Reply With Quote
Well I would be if I was applying now, but I had my first test on 27th April, so have until October 27th to get all the things sorted.
matt_gsxr
posted on 17/7/09 at 11:15 PM Reply With Quote
you should have asked the guy at the first test! Its not about the test, its about the rapport (except in Southampton, where no-one has a fair chance).
It needs to accommodate a rectangle 40mm high by 70mm wide.
Loads of other requirements (e.g. needs to view all the relevant things, no sharp edges, etc etc.)
Good luck.
Matt
james h
posted on 18/7/09 at 12:24 AM Reply With Quote
Cheers Matt,
I would have asked at the first test, but then again I would also have asked about the hundred or so things that I hadn't fitted to the car (eg. dash, boot panel, side repeaters etc. etc.)
Despite the massive fail sheets (yes, two of them!) the tester seemed like a really pleasant bloke, talking us through the test as we went.
Btw I was trying to get into the SVA system before IVA came in, hence the unfinished things.
James
