AdrianH
posted on 29/7/09 at 08:17 PM |
Shockprotectas for IVA
Has anyone tried these to protect the coil overs and passed IVA/SVA with them covering any sharp objects like the locking ring and adjuster?
http://www.visionplusuk.com/shockprotektas.htm
It seems a better bet then using a CV joint rubber.
Adrian
Why do I have to make the tools to finish the job? More time then money.
StevieB
posted on 29/7/09 at 08:27 PM |
I considered them but they were expensive from Demon Tweks (the only place I'd seen them at the time). Is that price for a pair?
I ended up using r/c car tyres top and bottom (for SVA not IVA) - passed fine and the tread pattern matches by R888's.
tomgregory2000
posted on 29/7/09 at 08:31 PM |
i got some bike inner tube, split it in length then wraped it round and glued it
cost = nothing
posted on 29/7/09 at 08:45 PM |
I used some left-over tadpole beading* wrapped around the adjusting ring, held in place with a tie-wrap (lumpy bit at the back, out of the way). I
used a plastic nut cover on the adjuster - it's still there!
* the stuff used between the rear wings and the body.
austin man
posted on 29/7/09 at 08:54 PM |
I used a cut down gland use by sparkies superglued the joint this was SVA though not IVA
Neil P
posted on 29/7/09 at 08:56 PM |
I didn't put anything on mine, not even nut covers and it wasn't commented on.
The only edge trim I put on the whole car was along the cockpit side rails and the outer edges of the front cycle wings.
Neil
AdrianH
posted on 29/7/09 at 09:32 PM |
Had not thought of using a nut cover on the adjuster, that is something I can try tomorrow, M12 I assume.
The price may be each not sure.
Thanks for the replies
Adrian
handyandy
posted on 29/7/09 at 11:32 PM |
Adrian, you have a U2U.
cheers
andy
mcerd1
posted on 30/7/09 at 07:18 AM |
old wetsuit + velcro + sewing machine = a few pence each
[Edited on 30/7/09 by mcerd1]
