Author: Subject: IVA rules for fuel fillers?
alistairolsen
posted on 6/10/09 at 08:51 AM Reply With Quote
Am I correct in thinking I need a lockable filler cap, with the cap tethered to the filler and the key on the same ring as the car key, with the ring welded so they cannot be separated?
In that case I assume a secondhand motorcycle cap would be suitable?
[Edited on 6/10/09 by alistairolsen]
My Build Thread
matt_claydon
posted on 6/10/09 at 08:59 AM Reply With Quote
The fuel filler cap must either be tethered to the vehicle or be of a lockable type where the key can only be removed when the cap is locked or an automatically opening and closing, non-removable fuel filler cap
tomgregory2000
posted on 6/10/09 at 09:01 AM Reply With Quote
not quite
The cap must either be teathered to the car OR must be the same key as the ignition.
it is so the cap can not be left behind when you drive off
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 6/10/09 at 09:14 AM Reply With Quote
As above, i can't take the key out of my cap without locking it and so i don't need to weld the ring or anything like that.
speedyxjs
posted on 6/10/09 at 09:35 AM Reply With Quote
It doesnt have to be the same key as the ignition does it?
iank
posted on 6/10/09 at 09:45 AM Reply With Quote
It's all pretty clear in the IVA manual section 03A standard 16
16. The fuel filler cap must either be tethered to the vehicle or be of a lockable
So the cap doesn't have to be lockable and if it is then it doesn't have to be the same as the ignition key, though the key must be captive while unlocked if it doesn't have a tether.
The problem with motorcycle caps is they don't have a funnel/spigot to connect a hose to as they are designed to be mounted on the top surface of a tank.
Anonymous
blakep82
posted on 6/10/09 at 11:17 AM Reply With Quote
download the manual below
________________________
tomgregory2000
posted on 6/10/09 at 11:18 AM Reply With Quote
not quite
My mistake sorry
Must be old age (24)
adithorp
posted on 6/10/09 at 03:44 PM Reply With Quote
Having a locking cap and the key on the same ring as the ignition key, prevents one of the most common ways of stealing cars; Hang around a petrol station waiting for someone to leave there keys in the ignition when they go to pay.
Having seen 2 people drive off in kits from the petrol station in the last few months I think a tether is a good idea. One did a few miles and returned to find the cap still on the pump and the other stopped 5 miles down the road to find the cap rolling about on the boot (jammy gits).
I'm going to rivet a length of chain to the bottom of my cap with a T bar (welding rod?) on the other end. Then just feed it into the filler and the T won't come out without a fiddle.
adrian
http://jpsc.org.uk/forum/
clairetoo
posted on 6/10/09 at 05:51 PM Reply With Quote
I once drove off leaving my filler cap on the pump in Leicester - I found out when I stopped for a top-up in Maidstone
Nowadays when I fill up I put the cap on the back of the car next to the fuel filler............and replace it BEFORE I replace the nozzle in the pump . I cant lock it since I lost the key
Its cuz I is blond , innit
Claire xx
Will weld for food......
irvined
posted on 6/10/09 at 07:47 PM Reply With Quote
To comply with IVA rules I tethered mine as my cap is locking but the key can be removed when its unlocked.
I used some chain used to secure a plug for a sink, i use a rivet to the plastic bit in the cap, and a clip around one of the air return holes in the unleaded flap.
http://irvined.blogspot.com
